Hi Friends,
I want to discuss how I can diagnose a suspected physical defect of the 100 V measurement range of the Keithley 238 I (A10) model I have.
A calibration procedure was conducted with a Keithley 6500 DMM with 6.5 digits of precision that was calibrated in August 2020. Let's assume that the accuracy is better than 0.035 % for this instrument, which would be sufficient to calibrate that Keithley 238. I have already calibrated another Keithley 238 this way, so I think it is reasonable to assume that this method works.
After calibration, the instrument was able to source voltages between 15 V to 110 V with high accuracy, according to my Keithley 6500, another Keithley 238, and a Keithley 2200-32-3. However, when measuring voltages at this range, the instrument is well outside of specifications. The table below represents these voltage measurements:
I performed another calibration procedure afterwards in an attempt to correct the shortcomings, but without success. It does not appear that results are a consequence of human error.
What I noticed while verifying the measurement ranges is that if I set the voltage compliance to 15 V, the Keithley 238 can measure 10 V precisely. However, setting the compliance limit to anything greater than 15 V will cause the instrument to use the 100 V range. The same 10 V measurement will read out of tolerance. I believe that the 100 V measurement range of this device is faulty.
On inspection of the service manual, it appears that the voltage sourcing and measuring are separated between two boards. The following simplified schematic appears to be what defines the voltage measurements.
Can anyone confirm this? I am a humble materials scientist and not electrically trained but I am trying to learn.
I also notice that there are strong resemblances between the Keithley 238 and Keithley 236/7 design in this context, so I think that the following electrical schematic applies. The major differences being the R18, R16, R 17 assembly for the 1000 V range, and the K7 relay.
If I had to guess the cause of the 100 V range measurement problem, I would say that it has to do with either R4 or R15. I know this to be true because the 1.5 V measurement range (K6) seems to be in working order. Before I start tearing the board apart, does anyone have advice for me on where I could start? I believe I have most equipment necessary to diagnose and repair the board, I just need help on where to begin.
Thanks for your thoughts and input.
Regards.
