Author Topic: Smartphone Touch Screen Replacement  (Read 1629 times)
Offline orbanpTopic starter
« on: August 02, 2018, 03:32:26 pm »
Hello Everyone,
My son dropped its phone, the glass on the screen cracked.
It is a Xiaomi Mi Max I phone.
The phone works just fine, and we put transparent packing tape on the screen as a temporary fix.
(The touch function still works!)
We got a replacement digitizer, the glass part of the screen.
However, the the glass and the LCD screen seems to be fused together, there does not seem to be an easy way to remove the cracked glass.
I heard some people using a heat gun...
Any advise on how to remove the glass without damaging/destroying the LCD part of the screen?
Thanks, Peter
Offline Doug Brewster
Re: Smartphone Touch Screen Replacement
« Reply #1 on: August 02, 2018, 03:54:18 pm »
Looks like this guy doesn't use heat...
« Reply #2 on: August 02, 2018, 04:29:50 pm »
Hi Doug,
Thanks for the link!
Looks like this guy replaced both the LCD and the glass, he used some adhesive tape in an "X" pattern.
That would not work for just the glass!
I did fond another video where they show the heat gun approach:
So it is doable.
Just curious what kind of industrial glue did they use to secure the top and bottom edges?
Thanks again, Peter
Offline Rasz
    • My random blog.
« Reply #3 on: August 02, 2018, 09:23:28 pm »
UV curing glue, but why bother? whole screen assembly is $22-39
