Hello,
My Samsung Blu-ray (BD-C5900) died (no lights - no response) and I've been trying to repair it. I'm pretty new to this and even newer at repairing SMPS supplies.
There was no output at all from the PSU. The rectifiers output looked ok and the bulk capacitor had 312v on it.
The thing is managed by one of these Infineon chips and the circuit diagram of the primary looks to be straight out of the manual.
http://www.infineon.com/dgdl/Datasheet_ICE3BR1765J_v2_3_19Nov2012.pdf?folderId=db3a304412b407950112b408e8c90004&fileId=db3a30431a5c32f2011a7a6a5b73688bI found the secondary winding that provides power to the chip and I found a spot where it appears to have arced over from the 312v track from the rectifier!. They are right next to each other! There is a corresponding burn mark on the case.
I guessed that this arc killed the chip, I ordered a replacement and replaced it.
So now I am getting secondary voltages but they come and go. If I scope the secondary windings I can see the high-speed switching come on then the period get longer and then shut down. Then it repeats. The 3.3v line comes up, the 12v doesn't seem to always get to 12 before it shuts down. There is a VFD- VFD+ and -VP line that seems to get to around 20v occasionally before cutting out again.
I saw somewhere that this can be caused by a cap drying out in the secondary side but none have bulges or any obvious signs of damage.
I am trying to decide if I should just replace the opto-coupler as it may have also been killed by whatever killed the Infineon chip.
I tried using the math function on my scope to make a differential probe and look at the output of the opto (the primary side) but it isn't clear if it is working or not.
I thought it might be in some power saving mode as it is out of circuit but when I put it back in the Blu-ray I get no activity on the front panel.
Any ideas for what else to check? I've gone through and checked all the diodes, inductors and transformer windings for continuity.
Tom
