The ferrite can be bridged if nothing else is damaged, but it is very unlikely. First you should make sure that the circuit that BD1 was powering is not shorted. Measure resistance between ground (shielding of the micro USB connector, for example) and the remaining pad of BD1, which seems to go to C28. If this rail is shorted, there's no point in bridging BD1.
