Author Topic: TDS310 Boot issue  (Read 1059 times)
Offline beubeuTopic starter
TDS310 Boot issue
« on: March 17, 2022, 09:34:45 pm »
Hello all,
I'm here because I bought a Tek TDS310 some weeks ago, all was fine since.. But today, something wrong appear !
There is an issue on the boot :
When I plug the 220v cable, the TDS start immediatly, without press the power button on the front panel. After the boot, the scope work fine, without problem. If I push the power button for stop the scope, sometime the scope restart after the pwoer down, sometime the scope stay in "standby" and I can"t power up again without witing 2-3 minutes !
It is a very strange issue :/
My opinion, is that maybe the power button is in bad condition (dust ?), or the PSU is in fault (caps ?)
At this day, I have not opened the unit, i prefer ask here if someone has already seen this issue :)
Help me please, i love my scope ^^
PS : there are no error codes in the log
Re: TDS310 Boot issue
« Reply #1 on: March 18, 2022, 08:43:58 am »
Hmmm I checked some topics, and the issue could be the switch button with the "carbon contact".
I will check this way this week end, but.. In this case, how can I repair this switch ? Carbon switch is not commun :/
« Reply #2 on: March 18, 2022, 07:18:44 pm »
Re,
it's me again ^^
I opened the scope, and check the power switch. It seems ok, nothng strange.
Next, I opened the PSU... And I think that the issue is here.
I tryed to follow the track of the "ON/OFF" signal, but the track desapear under some component and it is hard to see where he go !
The big problem is around a LM393, there is corrosion, I don't konw if the root of this corrosion is water or other liquid, I don't see anything strange on the cover of the PSU...
This PSU is manufactured by an external constructor, and I don't find the schematic... The tracks around the IC is very fragile, and the it will be hard t solve this issue :/
Edit : I tryed to follow the ON/OFF track, and.. the track finish to this LM393. So next step is to work on this aera :) Good job for this week end !
« Last Edit: March 18, 2022, 08:06:16 pm by beubeu »
« Reply #3 on: March 21, 2022, 07:25:39 am »
Re
It's a success ! TDS repaired :)
The root of the issue was the "big" secondary caps (1000u/25v), it seems OK, but after removing, I seen that the content leaked ! And all tracks below the caps was cutted or in very bad condition :/
So no other solution that add wires below the PCB for recreate the tracks ! You can see that on the pictures. Now all works fine yeaahh xD
The following users thanked this post: shakalnokturn
