Author Topic: Techniques for desoldering a PGA chip  (Read 1592 times)
Offline PeacefrogTopic starter
« on: January 08, 2022, 12:36:15 am »
I'm planning to desolder a 128 pin PGA chip with a Hakko 301 gun, and need a bit of help.
Before trying the real thing, I decided to practice on a junk board with a PGA chip - but I don't seem to be pulling the the solder clear of the hole, even if I add fresh 60/40 first and hold the board vertically. That said - I'm pretty wary of overheating the joint, and trying to keep the nozzle directly off the pad.
Can anyone offer advice?
« Last Edit: January 08, 2022, 01:10:00 am by Peacefrog »
Offline TheMG
Re: Techniques for desoldering a PGA chip
« Reply #1 on: January 08, 2022, 02:12:34 am »
Preheating the board will help a great deal, especially if large internal ground/power planes are involved.
Also, flux helps the solder to flow. Apply liberally, under the IC too if you can pour some in there.
Offline abdulbadii
« Reply #2 on: January 08, 2022, 02:39:38 am »
Use a hot air gun (station) IMHO the best way
Online coromonadalix
« Reply #3 on: January 08, 2022, 03:39:55 pm »
hot air to desolder a pga   lolll  you'll burn the board before it gets out,   you need to pre heat the board  Ie: give the ''pcb traces mass'' some help the get the solder out easily with an solder pump
Good flux will help  and  add flux many times as needed ... and yes adding  some 60/40   can / could help
But  you should practice on old or dead boards  before doing so
I do pga  without any problems, i work on chineeses pcb  with rohs solder (shitty)   have to refresh the soler with 60/40, and my Hakko desoldering pump is checked  tons of time to get it in optimal shape and maximum ''suction power"  i use some kleenex in place of the round filter pads in the handle,  since they tend to jam  very often, and the darn handle ''solder capture spring'' is removed
I heat the pins aroud 2-3 seconds max  and suck the solder
my 2 cents
Lots of flux, a good hand  and practice make you better ...
« Last Edit: January 08, 2022, 03:46:04 pm by coromonadalix »
Online voltsandjolts
« Reply #4 on: January 08, 2022, 03:45:52 pm »
Which bit do you want to preserve - the PGA chip or the PCB?
« Reply #5 on: January 08, 2022, 05:43:08 pm »
Definitely the PCB!
« Reply #6 on: January 08, 2022, 05:46:30 pm »
One thing - I do have a preheater, but there are SIMM sockets / plastic components nearby. Will foil or copper tape be enough to shield them? Is a heat gun  pointed to the other side of the board more practical?
Offline TheMG
« Reply #7 on: January 08, 2022, 06:56:26 pm »
You only need to preheat to between 100-150C. The vast majority of components should be able to withstand this temperature no problem.
It really makes a world of difference for ease of desoldering.
Offline benj38
« Reply #8 on: January 19, 2022, 01:15:38 pm »
In case you did not perform the surgery yet...
I highly recommend you use something like ChipQuik SMD removal Alloy. Look on amazon to get a feeling of what is available.
I have had great success with this in the past!
The main advantage is that the chance of ruining the chip or the PCB are almost nil. Also, you do not need to remove the PCB from the instrument (as you would if you preheat) if you can access the pins with a soldering iron.
The alloy looks like regular solder, but melts at a very low temperature of under 200 degrees Fahrenheit (similar to Wood's metal, but not so toxic). By melting it with a regular soldering iron onto the current solder (use lots of flux, it  does not wet as well as solder, and flood all the pins making a huge puddle), the resulting mixture stays molten at a very low temperature, and for quite long, allowing one ample time to safely remove the chip.
If you have an adjustable temperature soldering station you can do the whole thing with the station set to a temperature well below the melting point of normal solder. This will ensure that you have almost zero chance to damage anything. Make sure you clean all remains of it from the PCB, as you don't want the new soldered chip to have this mixture too. The ChipQuik website has clear instructions.
The only disadvantage is that this alloy is quite expensive from ChipQuik (though you do not need much for a single chip, making it very acceptable overall). I believe more reasonably priced alternatives also exist.
In fact, I have researched this years ago and figured out what the alloy must be and bought some small bars of it form a non electronics-related source. It was much cheaper than ChipQuik, works perfectly, but less convenient in a bar form than in the ChipQuik wire form. Unfortunately, I have not documented my findings, and forgot the exact generic name of the alloy.
Offline abdulbadii
« Reply #9 on: January 19, 2022, 02:23:05 pm »
low melt point material composition roughly
Bi ~ 65%
Sn ~ 17%
C ~ 14%
In  ~ 2%
S ~ 1%
O ~ 1%
