Author Topic: TEK TDS 420A firmware help.  (Read 1729 times)
Offline eurgencaTopic starter
  • Country: si
« on: September 16, 2021, 06:21:11 pm »
Hello.
I bought tek TDS420A with all LED on.
I was thinking it'll easy repair but... |O At first startup I smell caps. In PS i found 1 bad cap and replaced it. I check all other and looks O.K.
So PS running and all voltages are good.
Then I check 27K smd resistor on CPU board for reset and it is o.k.
On led diplay on cpu board it stops at "-" so cpu clearly running.
It is time to build console adapter and here is the problem:
        Bootrom Header Checksum passed.
        Bootrom Total Checksum passed.
        BootRom Check Sum passed.
        Bus Error Timeout test passed.
        Bus Error Write to Bootrom passed.
        GPIB Test passed.
Kernel Diagnostics Complete.
Calling SDM (monitor) Routine.
SDM (monitor) not enabled.
        Enabling Bus Control register. Value = 0x2
        Flashrom Programming Voltage is OFF.
        Flashrom DSACK and JumpCode test passed.
Invalid Flashrom Body checksum = 0x9115, should be 0x9105
Flashrom Checksum test failed.
Cannot transfer control to Flashrom.
Transferring control to the SDM (monitor).
Can someone help with this.
I suppose firmware is corrupted, but I can't find firmware on google. :-//
So if someone have firmware files and tell me how to flash this scope I'll be very glad. :-+
Sebastijan.
  • Country: si
Re: TEK TDS 420A firmware help.
« Reply #1 on: September 18, 2021, 09:02:28 am »
Hello.
Can someone please provide me a copy of firmware for TDS420A.
Regards, Sebastijan.
Offline madao
« Reply #2 on: September 18, 2021, 02:34:03 pm »
i have Firmware from TDS430A , it would work with your TDS420A..
But, i  am  not in house.
Pleas be patient.
Greetings
matt
  • Country: si
« Reply #3 on: September 18, 2021, 03:06:54 pm »
Hi Matt.
Thanks for help. I am glad that you willing to share FW.
No hurry I need to buy adapter first.
Offline madao
« Reply #4 on: September 19, 2021, 04:51:54 pm »
here
The following users thanked this post: sean0118, james_s, shakalnokturn, eurgenca
  • Country: si
« Reply #5 on: September 20, 2021, 05:33:24 am »
Thanks Matt.
Today I'll buy gpib adapter from max-bit and then will see...
Thanks again, Sebastijan.
  • Country: si
« Reply #6 on: October 03, 2021, 06:13:27 pm »
O.k. I received usb gpib cable and install ni software.
Connect TDS on PC and first made backup file.
When I was compare my file with Matt's file was significant change :-//. So I made next step, cleaning flash.
When confirming done I flash new file and ta daaa. works. :-DD
Now I must enable options and make some testing but for today I am done.
Thanks, Mat for help.
