Dear Smoky and guys
I am currently working on exactly the same Power Supply for a TDS420 that I am trying to resurrect.
Please excuse me for posting here but you already have fresh experience with this PSU. Regardless, I will create a new post on my repair procedure but I wanted to ask you if you could help me out on something in particular regarding the LF1 module from this power supply (it's the potted black Line Filter).
Here's the main problem I am facing (in short): I received this power supply with an exploded varistor (the taped one) while the diode was in good condition. I replaced them with a P130L10 varistor and a 1N5406T-G diode. Then, I fully recapped the supply, fixed some traces and replaced all the ICs.
Once ready, I plugged the supply to a fused 240 VAC line (UK mains) and the varistor went kaboom! Big big explosion!
. (see attached images)
Based on my measurements around the primary side from the PS I suspect that the problem might be an internal short in LF1. It has 3 leads that go to the points marked as E12 (orange cable) E4 (yellow cable) and E3 (blue cable).
I measured a dead short between E12 and E4. E12 goes to the negative pin from C1 and E4 goes to pin 2 from the bridge rectifier.
I wanted to kindly ask you if you could please measure the resistance between these two points to confirm that this short is my main issue (which I believe it is).
Once again, my apologies to all for flooding the thread with a new issue. I just want to confirm my suspicion based on someone who has a working supply.
Best wishes to you all
Cheers
dzalf
