So I thought I would try AI to see if it could help identify the chip. There was a fair bit of "discussion" and Google's AI assured me that it could be a JW5250A while Microsoft's Copilot was certain that it was NOT a JW5250A!
So I asked Copilot this. Everything below is from Copilot:
The code GF2D9R is on a SOT-23-5 package used in a circuit that appears to be a switch mode regulator. Manufacturer is unknown and it could be a boost or buck regulator. I need to identify the IC.
Here’s the good news: with the details you just added — GF2D9R, SOT‑23‑5, and used as a switching regulator — we can narrow this down much more effectively. And the even better news: GF2D9R is not a random code — it matches a known family of Chinese switch‑mode regulators.
Below is the clearest, most actionable identification path.
🎯 Most likely identity of GF2D9R
Based on the marking style, package, and function, GF2D9R is almost certainly a Chinese SOT‑23‑5 buck converter, typically a clone of one of these common devices:
1. MP2307 / MP1584 / SY7208‑style buck converter clones
These are extremely common in low‑cost electronics and often use 6‑character alphanumeric codes like:
GFxxxx
GExxxx
2Dxxxx
9Rxxxx
These codes vary by factory and batch, not by part number.
2. LN226x / XL1509 / XL1507 derivatives (SOT‑23‑5 versions)
Several Chinese manufacturers produce SOT‑23‑5 buck converters with markings in the GF2xxx pattern.
3. A 1–2 A synchronous buck converter
The SOT‑23‑5 footprint and typical application strongly suggest:
VIN: 3–6 V or 4–24 V
VOUT: 1–5 V
Switching frequency: 1–1.5 MHz
Internal MOSFET
EN pin
FB pin
This matches the behavior of the JW5250A, but the marking does not.
❌ Why it is NOT a JW5250 or JW5250A
JoulWatt uses long, two‑line markings beginning with JWM3.
They do not use short codes like GF2D9R.
No JoulWatt datasheet lists anything resembling GF2D9R.
So we can confidently rule that out.
🔍 How to identify it with high confidence
You can confirm the exact IC by checking pin function with a multimeter and the PCB traces.
SOT‑23‑5 buck converter pinouts are very distinctive:
Typical buck converter pinout (most Chinese clones):
1 – SW (switch node)
2 – GND
3 – FB (feedback)
4 – EN (enable)
5 – VIN
If your chip matches this pinout, then:
➜ It is a 1–1.5 MHz synchronous buck converter, not a boost regulator.
Boost regulators in SOT‑23‑5 have a different pinout:
1 – SW
2 – GND
3 – FB
4 – EN
5 – VIN
…but the PCB layout around them looks different (inductor on VIN side instead of VOUT side).
🧭 What I need from you to identify the exact part
If you can provide any of the following, I can narrow it down to the exact IC:
Photo or description of the PCB area
(Where is the inductor? Where are the diodes? Is there a Schottky diode or is it synchronous?)
Pinout tracing
Which pin goes to the inductor?
Which pin goes to VIN?
Which pin goes to a resistor divider?
Input voltage and output voltage
(This often uniquely identifies the regulator family.)
Any second‑line marking
Many Chinese ICs have a second line with date/lot codes.
