Author Topic: TL866  (Read 5579 times)
Offline lionelkjhTopic starter
TL866
« on: September 20, 2018, 11:26:15 am »
Hello; I am having an installation problem with my TL866 programmer. I have 2 years, and used several times the cd provided to install the software in the computer, without having any problem. But this morning; impossible to install; an error message appears at each installation: not available! .I have tried on the site directly: same thing! My desktop is an HP, operating system: windows 10, 64 bits. I have to read the contents of a memory M48Z02-200PC1 (not available either in the list of registered memories). Can someone help me ????? Thank you very much!
Offline Jon.C
  • Country: ad
Re: TL866
« Reply #1 on: September 20, 2018, 12:37:03 pm »
uninstall your version , reboot  and install last version
http://www.xgecu.com/en/
make sure of your model
is not in the list
« Last Edit: September 20, 2018, 12:43:34 pm by Jon.C »
Offline keymaster
  • Country: gr
Re: TL866
« Reply #2 on: September 20, 2018, 01:08:27 pm »
try to read it as , ds1220 .The datasheet says, that  is pin and function compatible . (page 5)(https://eu.mouser.com/datasheet/2/389/m48z02-955115.pdf)
Online 2N3055
  • Country: hr
Re: TL866
« Reply #3 on: September 20, 2018, 02:44:14 pm »
DS1220 is correct. Disable chip ID check if necesary.
Re: TL866
« Reply #4 on: October 16, 2018, 02:57:34 pm »
Hello everyone! I tried and tried again today, nothing to do, it's totally blocked! I even did a test on a second computer, downloaded the right version on the site directly; I get the same error message !! 2 years I own this programmer, and I have not encountered any problem installing software on the site or since the DVD provides! I wonder if the software is well accepted by windows 10, 64 bits! ??? Can someone help me ???? I attach the photo of the error encountered on the screen |O |O |O
Offline screwbreaker
Re: TL866
« Reply #5 on: October 16, 2018, 03:19:40 pm »
Just change the destination drive, from D: to C:
Re: TL866
« Reply #6 on: October 16, 2018, 03:36:04 pm »
ok, but how to go about it ???:palm:
Offline DaJMasta
    • medpants.com
Re: TL866
« Reply #7 on: October 16, 2018, 04:50:55 pm »
Click browse in the window under that, and pick another folder, or just type it into the line.
Installed this software just a couple days ago, don't know why it defaults to D:, especially since I don't have a D drive... but just selecting a different folder worked fine.  I'm having a different error when loading the software, saying "config file error", but despite that it seems to read and write fine with the exception of pin detection.
Online macboy
Re: TL866
« Reply #8 on: October 16, 2018, 05:59:07 pm »
You may not be able to install directly under C:\ since Win7 and up have permissions set to prevent modification of the root directory of the boot disk, mostly so that critical OS files can't be maliciously changed or installed.  I would recommend installing under "C:\Program Files (x86)\MiniPro".
Offline coromonadalix
Re: TL866
« Reply #9 on: October 16, 2018, 09:32:33 pm »
If youre on 64 bits, and the software ask for an upgrade,  the upgrade may render the tl866 useless until you re-flash it, i had to recover it in a 32 bit machine.
But the software run fine on win 10 x64 with no problems, not the upgrade in my case.
Normally the real software link is : http://www.autoelectric.cn/en/tl866_main.html  but it redirect to the same page look a like : http://www.xgecu.com/en/
Autoelectric are the original makers
And finally you have an tl866 thread on eevblog    you should continue there instead.
« Last Edit: October 16, 2018, 09:35:59 pm by coromonadalix »
Re: TL866
« Reply #10 on: October 19, 2018, 05:29:10 pm »
Good evening everyone! I thank you for all your explanations. Thanks to you all, my programmer works again. A true community of professionals! :clap:
Offline Dwi Kurniawan
  • Country: id
Re: TL866
« Reply #11 on: August 19, 2021, 02:00:59 pm »
Just Run as administrator and error is gone
Offline Miti
Re: TL866
« Reply #12 on: August 19, 2021, 03:44:07 pm »
I never installed that SW. Just download, unzip and run.
Fear does not stop death, it stops life.
