I think I might have found something in common on all the chips that have weird signals. Look at this:
This is another suspicious 74107, which is not shorted, but measures 2k\$\Omega\$ between 1J-1Q (same as the other one which had a dead short) — the rest of the 107s have a few Megs between those (which makes all the sense, given it's input to output).
The solder on the Gnd pin is slightly darkened, and there's a lot of it making like a tiny mountain. All other supposedly working chips have equally looking solder joints on all of the pads.
The 107 I've removed looked like that too, but I didn't pay too much attention to it — solder is solder who knows how it flows
and now it seems that the current at some point was so high that it melted the solder and caused it to flow down.
I've found a shop which sells really old and odd components NOS in here, so I'll go ahead and take out the suspicious chips, confirm the issue is in those chips and buy new ones as well as sockets for them (in case it's just an easy to kill design):
* 107-1: dead short in to out (1K to 1Q, pin 4 to 3). Recorded symptoms from my logbook: HOT!, output level ~1Q too low, 1Q too high, CLR and CLK squashed towards 3.4V.
* 107-2: 1K to 1Q is 1.3kOhm, 1K to ~1Q is 4kOhm. Symptoms: output 1 signal low, output 2 is nonsense mismatching the datasheet.
* 107-3: low resistance in to out (1K [or 1J, they're parallel on the PCB] to 1Q or ~1Q), is 2k\$\Omega\$ in both cases.
* 393-1, 393-2: 1A input to Vcc is 2k (2A, or 1A on 393-3, to Vcc is nearing MOhms)
* 32-1: 1A short to 1B (
Needs checking, maybe a short in 08-2 instead — but 08-2 doesn't have the Solder Mountain Syndrome), 3A has a weird pulse, 4A is also weird
* 04-2: 1A kinda low, Vcc to 1B is 13kOhm needs checking, has the solder mountain too, but 1B is an output to the "blanking" transistor base via a resistor, and base to 5V resistance in total is around the same...
Others so far seem to be fine... but what the heck happened to this thing?
Also I guess I need some more solder wick or some other tool to take out the chips
Oh and to add about the 8080 board... The PSU was going into protection because I determined the input polarity wrong
Before hooking it up to my bench PSU I looked at it more closely and oh shoot, the capacitors are backwards! Wait a second...
Not that like it's of any use with the dead ROM (the ROM was dead even before I powered it up for the first time, so unless someone did the same before me it died of some other cause. There are also pretty toasty chips on there too, despite the CPU clocking and all that now)
