Hello! I'm trying to crack a tough nut that's been plauging many other Apple HomePod owners. For some background, the homepod is a wireless speaker with only a power cable. No inputs, and everything from the power supply, to amp, to logic is all contained inside the unit. After ~8 minutes of idle, the HomePod will go into a low power standby mode and turn off some components. Any action wakes it up out of standby mode with everything fully powered again. The transition is almost instant.
The common problem is a dc offset voltage being introduced somewhere along the signal for the subwoofer. When measuring the subwoofer speaker output terminals, I typically see somewhere around ~200mV of dc give or take a few 100, and it steadily rises a few mV every second over time. The dc offset is only present at the subwoofer when the HomePod is not in standby...
I found some test pads on the amp board (first phot0) inbetween the amplifier IC for the subwoofer and the DAC. These appear to feed directly into the channel inputs on the amp IC.
When the homepod is not idling, the same dc offset is measured on these pads, however, when the homepod idles, unlike the subwoofer terminals, I can still see the dc offset voltage on these pads and the dc is slowly falling in mV until the homepod is awaken again.I was chatting with a redditor who was successful in resolving the dc offset by replacing the two capacitors (circled in red in second photo). I measured these as 10uF capacitors, they said they replaced them with 0.1uF capacitors?? I don't have any 0.1uF capacitors small enough to try the same yet, but I tried other 10uF capacitors and it didn't ahve an effect, so I think there's a different cause (at least for mine and many others)
I have a few of the amplifier boards for testing. I've depopulated one in an attempt to try and trace out some of how the board is layed out and been googling common causes for dc offset in audio amplifiers. I am still very much a beginner at all this and not sure what could be causing it or where to start, please go easy on me ;-;
Third and fourth photo is a high quality image of the amp board from the homepod from ifixit.
Datasheet for essentially the same amp IC chip:
https://www.infineon.com/dgdl/ir4302.pdf?fileId=5546d462533600a4015355d602a9181dDatasheet / schematics for an evaluation board featuring the same amp IC with a lot of similarities to the homepod amp board, if it helps?
https://www.infineon.com/dgdl/iraudamp18.pdf?fileId=5546d462533600a40153569a96eb2be9Datasheet for DAC:
https://d3uzseaevmutz1.cloudfront.net/pubs/proDatasheet/CS4350_F4.pdfiFixit's identified components on the homepod amp board:
https://www.ifixit.com/Teardown/HomePod+Teardown/103133#s192623
