Well my WAP300N showed up today, it has firmware version 1.0.01. I hooked my scope up to pins 3 and 4 of the UART connector, both rise to 3.3V after powering on, but I didn't see any data going across either pin. I starting to lead towards they just compiled out terminal support in later revs of the board, which would be easier than modifying the board layout. This board is a different revision than the image on the openwrt wiki, my board number ends in a 2 as opposed to a 1. So far I've only noticed the power switch is missing in rev 2.
