Author Topic: [Solved] Unknown component/device  (Read 1852 times)
Offline mnt22Topic starter
  • Country: jo
« on: June 06, 2018, 01:51:05 pm »
Hi
What is that component it goes by "EM"  on the PCB
Thanks every one.
« Last Edit: June 07, 2018, 05:11:13 am by mnt22 »
  • Country: jo
Re: Unknown component/device
« Reply #1 on: June 06, 2018, 01:55:25 pm »
Offline LateLesley
  • Country: scotland
« Reply #2 on: June 06, 2018, 02:35:53 pm »
I have no idea - but on the offchance it puts you on the right track, it looks similar to a ceramic resonator. I just came across a ceramic resonator in an circuit, and was looking for what it was. I hadn't come across them. And it does look a little similar to your component.
Good luck in identifying it.
https://en.wikipedia.org/wiki/Ceramic_resonator
It may also be a ceramic filter, I just stumbled across them.
https://www.google.co.uk/search?q=electronics+ceramic+filter&num=50&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjs9a_7oL_bAhUJzFMKHbwfDWkQ_AUICygC&biw=1528&bih=850
The following users thanked this post: mnt22
Offline picburner
« Reply #3 on: June 06, 2018, 04:35:51 pm »
I think it is a three terminal EMI suppression filter like these: http://www.globalsources.com/gsol/I/EMI-filter/p/sm/1001918177.htm#1001918177
The following users thanked this post: LateLesley, mnt22
Offline Chris56000
« Reply #4 on: June 06, 2018, 06:05:45 pm »
Hi!
That is indeed what it is - it's a capacitor with an input lead, an output plate and a common, forming a 'T' filter with two ferrite bead supressors, represented like this:-
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Offline ArthurDent
« Reply #5 on: June 07, 2018, 12:49:01 am »
Yup, EMC filter is correct. Here is a photo of a nearly identical one.
