. . .You can test the Thermocouple Sensor element yourself with a multimeter switched to the low millivolts d.c. range and another heat–source, a soldering–iron laid on the heater barrel might work, but the soldering iron wouldn't supply very much heat, as an alternative you can try a paint stripping hot–air gun (take care not to melt anything else doing so tho'!), whilst connecting the millivolt meter across the sensor leads – you should see a small increase in voltage as the heater barrel of the hot–air tool gets hotter!
. . .If you do get a change in voltage (it will only be very small!) then it's possible the thermocouple sensor may have been connected to the control PCB reverse polarity, not unknown in Chinese assembled units, and reversing the reads could solve the problem!
. . .If no difference, replace the sensor leads the original polarity if you tried reversing them – it might be worth repeating the thermocouple test I detailed above with your original tool that came with your station to verify both are giving a thermocouple voltage output!
. . .Another simple trick you can try is to make up a circuit consisting of a 1k 20 turn preset across a 9 V battery, connect the outer ends of the pot. to the battery and run two leads from the potentiometer wiper (middle pin) and battery negative, test with your millivoltmeter to set the pot to give 10 mV between wiper and battery negative, them connect these leads to the sensor terminals of the PCB with no hot–air tool plugged into the base OR the sensor leads from the socket disconnected (the thermocouple would short–circuit the test voltage otherwise!) – you can then turn the base station on and see if adjusting the test voltage pot. makes any difference to the display – if not you have a control fault within the PCB itself!
. . .If you find the Control PCB is not responding to a change in voltage from the tool, either by heating the hot–air tool barrel or by means of the test circuit I described above, please post good clear photos of the control PCB and we can suggest what else to check!
. . .It might also be worth using "Google Lens" with a photo of the PCB, you might find a new spare one of the same type on AliExpress or eBay!
Chris Williams
PS!
. . .Try a search for "858 Hot Air station" on Google or AliExpress – you might find that the "858" is the same base unit and hot–air tool, the Chinese sell these things under a multitude of brand–names and model numbers, and search this Forum as well – another Member might have drawn one out or posted a case history of a repaired one!
PPS!
Any help?
https://blog.enbewe.de/posts/2018-06-21-saike-858d-original-schematic/
