What level of heat must a satellite TV LNB be able to withstand?
In the blazing sun I measured a temperature of 60°C (140°F) on the outside of the LNB housing using an IR thermometer.
Many transponders between 11836 and 12610MHz (both H and V polarizations) are cutting out.
When I pour cold water (21°C/70°F) over it, reception on those transponders is restored (tested repeatedly).
Yesterday, I temporarily wrapped aluminum foil around it to prevent the LNB from heating up so much in the sun, but the foil blew away during a thunderstorm last night.
Consequently, the signal loss recurred this afternoon.
Questions:
Does it indicate a defect, or is it somehow normal?
If I buy a new Quattro LNB, what should I look out for?
Also, is the alignment—both axial rotation and shift relative to the dish's focal point—difficult or critical (I don't have any satellite measuring equipment)?
Are there markings on the LNB housing and the mount to assist with this?
Can I open the old LNB without throwing off the tuning?
