Author Topic: When thread lock runs out at factory...  (Read 3481 times)
Offline FireFlowerTopic starter
  • Wish had a cabin in Lappland
« on: June 20, 2018, 09:22:34 am »
 :palm:
Product: http://webshop.caliber.nl/products/view/details/bc108us.html
This unit is not too badly broken, just need to give it a bang and it usually starts playing. Probably there is a contact issue inside but who uses epoxy on the screws?
Online mariush
Re: When thread lock runs out at factory...
« Reply #1 on: June 20, 2018, 09:38:29 am »
That black stuff may be the kind of material that becomes slightly conductive with age, as it dried out.
I would scrape it everywhere it covers solder joints or contacts, as there may be low resistance paths between component pins or solder points.
Offline amyk
« Reply #2 on: June 20, 2018, 11:31:19 am »
I'm not surprised given that it's going to be subject to a lot of vibration in its intended use-case.
Is it a somewhat soft, silicone-type compound or really rock-hard epoxy? If it's the latter, then they did screw up. :palm:
Online stj
« Reply #3 on: June 20, 2018, 12:57:56 pm »
i have seen stuff that looks like that that had a flexable polymer type feel to it - you could pull bits off with pliers.
« Reply #4 on: June 20, 2018, 01:45:13 pm »
Rock hard epoxy
Online stj
« Reply #5 on: June 20, 2018, 06:22:00 pm »
then it's potting compound probably.
Offline Synthtech
« Reply #6 on: June 20, 2018, 08:01:11 pm »
Behringer?
« Reply #7 on: July 15, 2018, 05:56:17 pm »
Finally fixed this one... taking off hard epoxy was hell... had bake pcb in oven at 180C, then cut and scrape off epoxy...
And I only had to fix the damn speaker itself (speaker to terminal connection was not soldered properly)....  |O
Well at least everything is now soldered more or less properly, insulation has been taken care off, added thermal compound for power fets/transistors...
Offline james_s
« Reply #8 on: July 16, 2018, 01:41:17 am »
That is unusual, I've seen wax, adhesive that resembles "Shoe Goo", and various paint/lacquers used but I don't think I've ever seen epoxy potting compound used as threadlock. Maybe they had some leftover from potting a run of something else and just decided to use the same stuff?
Offline CatalinaWOW
« Reply #9 on: July 16, 2018, 03:30:25 am »
More likely someone in purchasing found a discount and had a "gunk is gunk" mentality.  Early in my career I had a battle with a buyer over why a really cheap 2N2222 knockoff could not be substituted for the power output transistors in one of our products.  He had checked and found they were fully compatible (NPN and three terminals).  He literally asked me "transistors and transistors aren't they?"
I had to bring in my boss to help.  I was an engineer and knew what I was talking about, but had no seniority or purchasing authority so only roughly balanced the decision power of the buyer.
Offline james_s
« Reply #10 on: July 16, 2018, 04:06:36 pm »
I would have been tempted to just say "Sure, if you say so" and just make sure it was known who made the decision to substitute those transistors when the whole production run fails.
