Just had a look at the datasheet of those capacitors and the capacity tolerance is +/- 20%, so -18% is within tolerance. (and that's also assuming that your measurement device tested at 120Hz....)
For the primary buffer-electrolytics in a SMPS the slightly lower capacitance is not an issue at all.
Most circuits aren't very critical or demanding w.r.t. tight tolerances of capacity. Capacity is very rarely a problem with electrolytics, you can often get away with much less or more capacitance in most applications (time-sensitive applications excepted).
should I use them anyway?
Myself, I'd have absolutely no qualms whatsover using them.
Were the original capacitors bad? Only problem I can think of is ESR, but for THOSE capacitors (primary/high voltage section buffer electrolytics) ESR is rarely a problem; it's usually the secondary side, where currents are much larger, that capacitors go bad because of overheating/high ESR.
I'm was planning to exchange the main caps in the PSU
You mention it's not a repair; then why are you replacing those capacitors?
