Hmm I did not thing of the switches, are they that cheap and prone to fail
The pots i all checked out, desolderd them and check out how the behave with my multimeter, they are good, also the fact the control room out is working fine takes the pots off the list... unless someone here decided to a very creative way of dealing with how a pot is connected to audio line
Well i did ask around the local suppliers, usually they have stuff but they seem to have no stock on the SIP8 pack on this thing, tho i found it on ebay.
For now I ordered the excat same ones as i have, branded as coolaudio (never heard of this IC maker... anyone ?)
As for the cause i suspect it was my headphone cable, i did run it over with my chair once and the sound they headphones made back then made my ears bleed... like i said I dont know much about audio stuff but would a shorted output duing playback with headphones a bit on the strong side (150 ohm cans) cause a opamp to fail. It has nothing after the IC other then one 47k resistor, between the jack and the output of the opamp
As for pictures I had to close the mixer for now, the crackling is gone so recording at least is no longer a issue.
If someone can take a look at the schematic and tell me other possible places of fail for the headphones out, its on page 6, the phones out is missing left channel, CR bout L and R work both fine. I suspect the part marked as IC1B as failed
https://www.dropbox.com/s/k073s5dzfs2gse3/behringer_xenyx_1204fx.pdf?dl=0
