Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Yamaha RX-V659 Power problem
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Yamaha RX-V659 Power problem (Read 4373 times)
ysonmezer
Newbie
Country:
on:
May 27, 2017, 08:04:05 pm »
I use a Yamaha RX-V659 receiver. I had previously burned the capacitor on the power board 22nf 630v. I changed it with 22nf 1000v so that it would burn again. The device recently made a power failure. This condenser series had a 220k resistor burned. I changed but the device did not work. These two components are attached to the series burnt surface mount 10v zener. I changed and worked.
Logged
mzacharias
Frequent Contributor
Country:
Re: Yamaha RX-V659 Power problem
Reply #1 on:
May 29, 2017, 11:58:43 am »
R661 should be 2.2K (2200 ohms) not 220K.
Logged
oldway
Super Contributor
Reply #2 on:
May 29, 2017, 04:22:39 pm »
And C654 must be a X2 capacitor for safety.
With C654 = 22nf 275Vac
X2
, you should never burn R661, nor the zener diode.
Last Edit: May 29, 2017, 04:27:38 pm by oldway
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
