Author Topic: "Automatic", cheap wire strippers -do they deliver?  (Read 32964 times)
Offline nanofrog
Re: "Automatic", cheap wire strippers -do they deliver?
« Reply #75 on: September 22, 2017, 10:52:39 pm »
Based on appearance and molded markings, the Capri and Pro's Kit seem to be the same unit. So this could be a nice find for other members in the market for a non-nested type automatic stripper.   8)
Didn't find a COO for it, so that's good to know as well.  :)
Offline shteii01
« Reply #76 on: September 23, 2017, 03:32:46 am »
Offline kPATm
« Reply #77 on: September 23, 2017, 04:32:02 pm »
Have you ever seen something like this? I came across these for the first time today, and then again a second completely unrelated time (that kind of deja vu happens to me a lot).
https://www.parallax.com/product/700-10001
I don't have one, but it looks useful.
I use these and they are pretty good
« Last Edit: September 23, 2017, 04:34:14 pm by kPATm »
Offline shteii01
« Reply #78 on: September 24, 2017, 02:12:57 am »
edavid, thank you for assembling the list and info.  Very helpful.
I was looking at Jokari and Weicon.  Jokari does not show replacement blades, while Weicon does.
Offline edavid
« Reply #79 on: September 27, 2017, 12:12:51 am »
The Capri arrived, and so far I'm quite happy with it.  On teflon wire it sometimes takes 2 attempts, but that's fine.  Otherwise it strips on the first try.
Offline nanofrog
« Reply #80 on: September 27, 2017, 01:29:34 am »
You can also experiment with adding pressure to the closed jaw with your hand before pulling the handle to actually strip PTFE (makes a deeper bite into the insulation).
I have to do this with old, hardened PVC wiring at times as I can't adjust it sufficiently (scrapes the insulation instead of stripping it). The V shaped jaws are a bit better with this IME, as it makes more bites into the insulation.
Offline RJFreeman
    • Australian Technical Production Services
« Reply #81 on: September 27, 2017, 01:50:19 am »
I'm in need for a wire stripper and there are numerous discussions/comparisons here on the costly "pro" ones, but what suffices for hobby use? I'm staying away from the cheapest ones, assuming they'll break down in a couple of days, but there are a few claiming to be "automatic" and which I've read blogs and postings (not here) about from people who find them very nice:
Are they any good and do they last?
I made the mistake of buying a pair of them, they are utter rubbish, as they just rip rip the end of the wire off, rather than strip it.
I have tried adjusting the tension, but they go from not doing anything, to tearing the end off the wire, there is nothing in between.  |O
« Last Edit: September 27, 2017, 01:56:52 am by RJFreeman »
Offline mySystemEngineer
  • Country: il
« Reply #82 on: October 09, 2017, 10:27:30 am »
you should select a model that can strip up to 28AWG or even 30AWG, they are common widths for fine projects.
Offline JonM
« Reply #83 on: October 17, 2017, 04:05:27 am »
I have a version of that stripper and it works very well down to about 22G (but not for Teflon insulated wire). For smaller wire I usually select a small Paladin stripper.
