Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Other Equipment & Products
Affordable lab power supply, 1 channel, 0-60 Volts
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Affordable lab power supply, 1 channel, 0-60 Volts (Read 1333 times)
Ranayna
Frequent Contributor
Country:
on:
July 22, 2021, 02:00:51 pm »
while i own a Rigol DP832 with which i could couple the channels, it is just to fiddly and too loud to work with most of the time, especially when i do not need its relative precision.
I also have a cheap 0-30 single channel supply that is just dead-easy to use, but i now have need for a 0-60 volt supply. Actually 0-50 would already be enough, but those seem uncommon.
My current use-case requires less than 1A, but some additional power might be useful in the future.
I know to avoid the absolute cheapy like this:
https://www.amazon.de/-/en/MCH-K605DN-Precision-Supply-Adjustable-Stabilized/dp/B07PG8XT28
But there are many supplies similar to that:
https://www.amazon.de/-/en/Laboratory-Adjustable-Alligator-Overload-Protection/dp/B08GHN5HMN
With additional fine knobs:
https://www.amazon.de/-/en/Laboratory-laboratory-adjustable-electronics-electroplating/dp/B081N2Q5LV
What would be an acceptable device, if possible for a budget of around 100 Euro?
Settings via coarse and fine knobs would be preferred over digital setup by far.
No special requirements about precision.
Semi-passive fan (or outright fan-less) would be great, otherwise a reasonable fan noise, less than the Rigol please.
Reasonable build-quality with no obvious safety issues.
There is a boatload of these supplies available on Amazon alone. Are there any that stand out in a positive sense?
Logged
Gregg
Super Contributor
Country:
Re: Affordable lab power supply, 1 channel, 0-60 Volts
Reply #1 on:
July 22, 2021, 07:36:04 pm »
Gophert makes some 60V switching power supplies within your budget. I have a couple of lower voltage Gophert power supplies and they are reliable; maybe not the smoothest output, but pretty good for the price.
VoltLog did a video about one he has as well as a post on this forum.
Logged
Jeroen3
Super Contributor
Country:
Embedded Engineer
Reply #2 on:
July 22, 2021, 07:41:41 pm »
Why not replace the fan in the rigol for a noctua one?
https://www.eevblog.com/forum/testgear/dp832-fan-replacement-2018/
Otherwise, reichelt sells peaktech, may be something, the 6227 perhaps?
Last Edit: July 22, 2021, 07:43:14 pm by Jeroen3
Logged
Ranayna
Country:
Reply #3 on:
July 23, 2021, 06:32:15 am »
I have seen the Peaktech 6227. That would be my *utmost* budget limit.
But that frontpanel looks, well, odd. I would have no use for those 2 USB Slots, and they axed a second knob for those...
I have now looked at some Gophert supplies. They are aparently fan-less, so that would be a plus in my opinion. That might even outweigh the single knob interface.
But i am reluctant to order one of those directly from china.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
