I need to source an air compressor to feed the soldering gun on an MX-500. Their literature recommends an air pressure of around 80 PSI/~5.5 Bar. I had a look at RS (there is an existing account) and I can only find large compressors like this:
http://radionics.rs-online.com/web/p/air-compressors/6934902/ This sees like overkill and I don't want to deal with a large motor. Are there smaller, quieter compressors available that would work here? I have seen desoldering stations with integrated airflow systems that were pretty small and seemed to handle most jobs just fine.
The airflow is pretty low - may be worth looking at things like used dental gear, or something else that uses small volumes of air. Maybe even a bottle of CO2 or nitrogen ?
I wonder if a cheap tyre inflator might do the job.
Another alternative that would meet the quiet criteria is a refrigeration/aircon compressor. An issue with these is the need for them to have oil, and to use an oil filter on the output, but they are small, quiet and cheap. You sould be able to find some resources online about using/converting them
In my experience at least Hakko with similar venturi /vacuum ejector is quite hungry for pressurized air?
Integrated desoldering station pumps are bit different case as those are vacuum pumps and power requirements for those are less than using compressed air and venturi to create vacuum.
I dont have pressurized air and I did not want desoldering station with integrated vacuum pump because those are somewhat slow, often noisy and not creating as much vacuum as good vacuum ejector. My solution was to use solenoid valve and fridge compressor for pulling vacuum. Works like a treat, quiet, strong vacuum, fast response and cost nothing.
I have used an air bottle, it worked well but isn't ideal for a permanent setup. There is a nitrogen feed available but I would prefer to avoid using it if possible as it would mean filling out safety paperwork.
I'm not sure tbh. I was hoping that even a loud compressor with a reservoir tank should last through a lot of desoldering without requiring the tank to be refilled?
Sure, you can run quite long times with big reservoir tank, average air use is low because you probably use it in short burst less than one second.
We managed to buy a 5000 series Metcal at work before realising that the compressed air supply had been removed from our building. We now use one of these,
http://www.machinemart.co.uk/shop/product/details/shhh-air-compressor-39Pretty expensive, but very small and very quiet compared to the industrial ones. I think there are cheaper variants that might be a bit smaller, worst comes to the worst you may have to wait for a minute or two for the tank to recharge
PSI is not what makes a compressor expensive , it is the CFM [ cubic feet per. min. ] that make a compressor expensive .
Look for that spec. from Metcal to find the minmum CFM , But I would recommend larger than what is required for the [ desoldering gun ] because if you'er setting up a bench , you would find so many other uses for its use that something around 4-8 CFM would cover lots of other tools .
Then the issue is if you buy chineeze junk , you end up replacing frequently , and shortly exceeding the cost of quality .
" Bitch one the 1st time when you buy quality , rather than every time your use junk "
I have found lots of used gear free to cheap and repair for less than half the value .
I use this Bambi compressor in my workshop. It charges quickly and is very quiet. It's also rather a lot cheaper than the Machine Mart variant, and it's made in England
http://www.axminster.co.uk/bambi-bb24v-compressor-prod21502/
In the past, I've used an air storage tank charged by a fairly robust tire inflator. I'm in the process of putting together a Metcal station with the venturi desoldering gun, so I'll probably go that route again unless I can find a small cheap compressor. The duty cycle is so low even a cheap compressor will last a long time.
If anyone gets this setup could you please post details of the hoses used and their connectors. I have one of the Metcal MX-5000 desoldering units at work which isn't being used because there is no compressed air available.
Thanks.
David.
the perfect air compressor is the one from andymark I used it as a onboard compressor for a robot I recently built and it can pump out about 200psi but we had it regulated at about 160 high and 60 working pressure its a great little unit you can buy the starter kit from AndyMark.com for around 100 bucks and I you have any background with pneumatics like me then you can set it up to have quick connects and be able to power pneumatic cut off wheels or even just to blow off the workspace what ever you heart desires and this compressor runs off 12v so you could always buy the ac to dc convertor it makes a great little compressor over all
Thanks.
David.
Well, it's 2 years late for this thread, but I've just bought a Metcal MX5251 which includes the desoldering gun. The air fitting is a 'Milton M-style' coupling (as far as I can make out, but I can't find this anywhere in Metcal's literature) which I can't find anywhere in the UK on a reasonable lead time. Very common in the US. I removed the Milton connector from the air hose and used a 1/8" NPT27 to 1/4" BSP reducer (specifically
http://www.ebay.co.uk/itm/131225693084). The NPT thread is again very common in the US. 1/4" BSP means the world's your oyster.
I ended up using a cheap 1 gallon oilless air compressor marketed by Harbor Freight. Not a great compressor, but it was around $35 US and works well with the Metcal. It's a little loud, but I have it stuffed in a cabinet that muffles the noise.
If it uses a universal motor like many cheap compressors do, add an inline diode and it will run cooler and last longer.
