Here is the output from the serial port after power on (115 kbps):
NPT
VBUS PON
Loader NT96655 Start ...
655B_DDR3_LV1_3_1024Mb 04/27/2017 09:16:12
RRRRRR
RFlshR
FCompressRHello, eCos world!
_main(): (_main begin)
_main(): (reg exp handler)
_main(): (kernel init)
_main(): (Install code section)
_main(): (Install code zi)
_main(): (Install Drv ID)
_main(): (Install User ID)
_main(): (Install User ID for mempool)
======== Kernel Memory Summary ========
[33mTotal Region: Range[0x80000000~0x88000000] Size=0x08000000
[0m[32mCode Region: Range[0x80000000~0x80F00000] Size=0x00F00000, UsedEnd[0x80F00000], FreeSize[0x00000000]
[0m[32mStack Region: Range[0x80F00000~0x80F00000] Size=0x00000000, UsedEnd[0x80F00000], FreeSize[0x00000000]
[0m[32mHeap Region: Range[0x80F00000~0x87FFE000] Size=0x070FE000, UsedEnd[0x80F00000], FreeSize[0x070FE000]
[0m[32mResv Region: Range[0x87FFE000~0x88000000] Size=0x00002000
[0m
======== Kernel Resource Summary ========
[32mTask : Total=68, Used=61
[0m[32mFlag : Total=128, Used=60
[0m[32mSem : Total=128, Used=123
[0m[32mMbx : Total=12, Used=3
[0m[32mPool : Total=32, Used=26
[0m_main(): (kernel startup)
_main(): (_main end)
dma freq = 372 MHz
cpu freq = 432 MHz
CPU/OCP/APB = 432/432/80 Mhz, DMA = 372 Mhz
Clk verify PASS
NT96650 SDK
Copyright (c) 2012 Novatek Microelectronic Corp.
Hello, World!
> Enter DSC
bind - begin!
bind - end!
event loop - begin!
[31mERR:FM25Q32_identifySpi() =====SPI flash uiMfgID=ef, uiTypeID=40, uiCapacity=16
[0m[31mERR:ramdsk_setParam() No Implement! uiEvt 1
[0m[31mERR:PartLoad_Init() Loaded Addr 0x(806092D8)!= Verified Addr 0x(801E6000)
[0m[31mERR:xFwSrv_Err() -21
[0m[31mERR:System_OnStrgInit_FWS() Init failed!
[0m[32m[LOAD-FW]
[0m[32mTotal Sections = 10
[0m[32m Section-01: Range[0x80000000~0x801E566C] Size=0x001E566C (LOAD)
[0m
LD VERISON: LD655
FW --- Daily Build: Nov 22 2017, 17:14:56
PhotoExe_OnQuality(): 0
PhotoExe_OnISO(): 0
PhotoExe_OnEV(): 6
PhotoExe_OnWB(): 0
PhotoExe_OnMetering(): 3
PhotoExe_OnSize(): 4
PhotoExe_OnSceneMode(): 0
[31m Parameter error in Get_SceneModeValue()
[0mPhotoExe_OnColor(): 0
[31mERR:Ux_GetBaseType() unknown type 512!!
[0m[0]Low power Cmd => 0x11
[1]Low power Cmd => 0xff
[1]Low power Cmd => 0xc0
[1]Low power Cmd => 0xc1
[1]Low power Cmd => 0xc2
[0]Low power Cmd => 0xc7
[1]Low power Cmd => 0xb0
[1]Low power Cmd => 0xb1
[0]Low power Cmd => 0xb0
[0]Low power Cmd => 0xb1
[0]Low power Cmd => 0xb2
[0]Low power Cmd => 0xb3
[0]Low power Cmd => 0xb5
[0]Low power Cmd => 0xb7
[0]Low power Cmd => 0xb8
[0]Low power Cmd => 0xc1
[0]Low power Cmd => 0xc2
[0]Low power Cmd => 0xd0
[1]Low power Cmd => 0xe0
[1]Low power Cmd => 0xe1
[1]Low power Cmd => 0xe2
[1]Low power Cmd => 0xe3
[1]Low power Cmd => 0xe4
[1]Low power Cmd => 0xe5
[1]Low power Cmd => 0xe6
[1]Low power Cmd => 0xe7
[1]Low power Cmd => 0xe8
[1]Low power Cmd => 0xeb
[1]Low power Cmd => 0xec
[1]Low power Cmd => 0xed
[0]Low power Cmd => 0x36
[0]Low power Cmd => 0x29
dispdev_openIFDsi(): Original SrcClk(297)Mhz
dispdev_openIFDsi(): DEVDSI: Chg PLL2 to(480)Mhz
[31mERR:DrvLCDState() state=0x06 not support!
[0m[DOUT1]: device = [Display_LCD], state = [STOP], mode = [0x0d, 864x480]
[DOUT2]: device = [N/A], lockdevice = [N/A]
[31mERR:Ux_GetRootWindow() wnd not created
[0m[31mERR:idec_setOsdWinAttrEx() Vertical Scaling down ratio over 2!
[0m[31mERR:Ux_GetRootWindow() wnd not created
[0m[33mWRN:sdioHost_setBusClk() SDIO host0 : real clock (396694Hz) is not equal to desired (399000Hz)
[0m[33mWRN:sdioPrtcl_getCardInfo() SDIO0: WARNING!usCSDReadBlkLen is not 512
[0m[31mERR:Ux_GetRootWindow() wnd not created[0m
<<=====================GPIO_i2c_write_byte=======================>>
<<=====================_i2c_ack_detect=======================>>
<<=====================_i2c_stop=======================>>
[31mERR:FST_CMDGetFileLen() File not found
[0mERR: System_SetSSID 0
Character length error.
[0mERR: System_SetPASSPHRASE 0
[35mMode {MOVIE} Open begin
[0m[35mMODE -1->2
[0m[31mERR:Init_AR0330M() Init_AR0330M...
[0m[31mERR:Init_AR0330M() ^GOTPM v5
[0m[31mERR:Init_AR0330M() ^GChip version is 0x2604
[0m[31mERR:ChgMode_AR0330M() ChgMode_AR0330M to 4...
[0m[31mERR:AF_Open() #Register AF event table.
[0m[31mERR:IPL_SIEClkCBFlowC() SIEclk = 240000000
[0m[31mERR:pre_open() PLL6 selected but not enabled...
[0m[31mERR:IPL_SIESetCAVIG_FCB() CA VIG Setting not ready
[0m[31mERR:AF_Tsk() #Entered AF_Tsk
[0m[31m no CB2222222
[0m[31mERR:Perf_Open() already opened!
[0m[31mERR:IPL_FCB_Alg3DNR() ^G3DNR on..
[0m[31mERR:IPL_FCB_AlgWDR() ^GIPL_FCB_AlgWDR = 6..
[0mfileid:3
PhotoExe_OnWB(): 0
PhotoExe_OnEV(): 6
[31mERR:IPL_FCB_AlgIE() ^GWDR OFF..
[0mERR: g_uiWndMovieRecordFirst = 0
[33mUSB 1.5A
[35mMode {MOVIE} Open end
[0m[33mUSB 1.5A
[0mGxPower: Stop low-battery check.
GxPower: Start to Charge Battery
[31mERR:DrvPower_SetControl() DrvPwrCtrl(11)
[0m[31mERR:DrvPower_SetControl() DrvPwrCtrl(12)
[0m[31mERR:DrvPower_SetControl() DrvPwrCtrl(9)
GxPower: Start t[33mUSB 1.5A
[0mo0m[31mERR:DrvPower_SetControl() DrvPwrCtrl(11)
[0m Battery Insert = NO
[33mUSB 1.5A
[0m[33mUSB 1.5A
[0mUSBConnectType=2
NO Battery, Ignore START
ERR: AC is plugged, GPIOMap_DetAC = 1
Remote Control - Freeze 2 x:
[0;35muiDataContent=0xF807FF00[0m
[0;35mkey=0x01060030[0m
[0;35mparamArray[0]=0x0106000F[0m
Peter
