Author Topic: Are cheap Ebay switch-mode Power Supply Units any good?  (Read 25557 times)
Offline dannyf
Re: Are cheap Ebay switch-mode Power Supply Units any good?
« Reply #25 on: February 26, 2015, 03:06:43 pm »
I wonder what the conclusions would have been if the maker had not known the brands and the prices?
It would be hilarious and highly revealing, both about the projects being reviewed and the reviewers doing the reviews. That's why you will never see it done.
Most of the product reviews you see are predictable: the expensive ones are always the better ones, the brand name ones are the better ones, ....
Such reviews tell far more about the reviewers than the products being reviewed.
It is in that way I find this particular review (of switching mode power supply) highly interesting and refreshing - it recognizes the shortcomings of the cheaper unit but tries to put such shortcomings in perspective vs. the more expensive unit. That kind of information is highly valuable to a potential user of those units.
Offline JohnnyBerg
« Reply #26 on: February 26, 2015, 03:19:47 pm »
I agree.
Except for the last 45 second of the video. The maker concludes that the more expensive unit will last much longer the the cheap one. No proof of that, of couse.
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #27 on: February 26, 2015, 04:01:02 pm »
Don't have audio here so can't do much with the video, but it would seem to me the Cosel has PFC, no? If not, it would seem there's a bit much magnetics on the board... :-//
EDIT: hmmm, checked the datasheet of the controller. No PFC. Odd... I suppose it's a flyback + buck for additional accuracy or some such then?
« Last Edit: February 26, 2015, 04:06:31 pm by Ice-Tea »
Offline JohnnyBerg
« Reply #28 on: February 26, 2015, 04:11:34 pm »
As there is only 1 power mosfet, I asume it is a flyback converter.
IMHO the real deal would be be a PFC boost converter to 380V line, and the some kind of half bridge.
Would have love to see the more expensive PSU on 90V in with max output power. Currents though are highest then.
Offline dom0
« Reply #29 on: February 26, 2015, 04:14:38 pm »
The two inductors and black caps in the image on the lower left edge of board is likely the input filter. PCB spark gaps over the inductors suggest that, too. Also the splitted resistors across the two traces there indicate this.
Offline Ice-Tea
« Reply #30 on: February 26, 2015, 04:46:28 pm »
I already modified my original post as I checked the controller and it seems only flyback controller. But thereare two power FETs, hence my suggestion it is perhaps a flyback + buck.
Offline JohnnyBerg
« Reply #31 on: February 26, 2015, 04:48:32 pm »
Do you really think that the manufacturer of a $8 power supply has extensively tested it over a long period of time, and has extremely high standards for production and testing?
Why not?
Labor in China is cheap, and the plants I visited all had large climate controlled test chambers for burn in.
I'd be really happy if one of these manufacturers making $8 power supplies could release all their test data and demonstrate that their hardware is as good as a $80 PSU. Why do you think they don't do that?
Does the $80 PSU manufacturer release all the test data?
You are making a lot of statements and assumptions, without any proof.
Perhaps you should pay a visit to Shenzhen. It will broaden your horizons :)
note: I am not saying that everything that comes from China is good. There is a lot of crap coming from there. What I am saying that every product should be reviewed on it merites, and unbiased.
Offline JohnnyBerg
« Reply #32 on: February 26, 2015, 04:52:28 pm »
I need new eyes, as I only see 1 mosfet? The other TO-220-isch device are 2 diodes with common cathode?
Offline Ice-Tea
« Reply #33 on: February 26, 2015, 05:00:11 pm »
Apparently. I just assumed   :-\
« Reply #34 on: February 26, 2015, 06:14:35 pm »
There is active PFC in there, the choke next to the mains capacitor and the little silver heatsinked device next to the white power resistors along with the 3 diodes say that. Then the main TO247 switching mosfet and the power transformer, then the output diode at the bottom. LC filter on the output is also a nice thing they added, reducing ripple a lot.
Offline Ice-Tea
« Reply #35 on: February 26, 2015, 06:28:27 pm »
That's what I thought at first, but the controller does not seem to be a PFC controller?
« Reply #36 on: February 26, 2015, 07:34:14 pm »
You do get single chip PFC regulators, and there must be somebody putting the PFC and controller into a single package somewhere for this use. 5 pin TO220 package has enough pins (barely) for this to fit, especially at low power levels where you will likely be seeing active PFC as a retrofit to a supply design.
Offline Ice-Tea
« Reply #37 on: February 26, 2015, 08:38:04 pm »
You can find the controller on the bottom. Does not seem to be PFC....
Offline JohnnyBerg
« Reply #38 on: February 26, 2015, 08:46:49 pm »
Controller is a M51995
Offline loneoceansTopic starter
    • Loneoceans Laboratories
« Reply #39 on: February 26, 2015, 11:43:36 pm »
Wow I have no idea this thread became so popular!  :scared:  As mentioned, the goal for this video was simply motivated by the fact that I was needing a reliable 24V power supply for my projects, and I happened to score a $80 supply on ebay for really cheap 2nd hand, so I was very curious as to why it was so expensive, and the differences between the cheap ebay supplies which I have been using for some time. I don't claim to be an expert in PSU design, but I do have some background in electrical engineering, and thought I'd make a video since others might be interested.
For the record, I also agree that $80 is really a bit too pricey for a power supply, and I have decided to use the more reasonable $20 Delta or TDK Lambda supplies for my projects (I made a follow up video for the Delta supply) because they represent much greater value. Also to try to set this straight, I think I'll do a second investigation on the many points you guys bring up, and hopefully we'll all learn something new  :-+
Nope, it has not.
Generally speaking, most reviews I watch are often biased in the advantage of the more expensive or big name device. Chinese and cheap is mostly crap. Headers like "Are cheap Ebay switch-mode Power Supply Units any good?" or "Why UNI-T multimeters suck" are pretentious and not objective.
IMHO the $80 PSU does not give value for money. No PFC, the soldered glass fuse, no synchronous rectification. I would expect those things in a $80 / 50Watt PSU.
A more critical approach for the "big" brands would be appreciated!
I think I did make it clear that the Cosel did seem to have poorer ripple, which really surprised me. I also never intended to think that the cheap supply was 'mostly crap'. However upon opening them up, many things already raised red flags, like cheap capacitors (which I know for a fact do fail), dodgy soldered components (did I mention, in another similar $8 eBay supply, I had to open it up and re-solder the adjust pot because the solder joint was loose?), and the fact that it lacks significantly fewer components, probably means that they had to cut some corners. I'm not saying that it will, but as a customer, who wants some confidence that this supply won't suddenly fail and bring my expensive project down with it, having confidence (and warranty) in a product does mean something.
I would like to invite you to also check out the Delta power supply comparison, where you can see that the topology is very similar, but the Delta does everything better with more attention to detail, and most importantly, using known high quality components AND publishing detailed details on thermal and electrical performance. Also, the Cosel is a forward converter topology for sure, and I just checked the product guide overview and it says it does use a forward converter topology so that settles it.
Well in a field like this you almost always get what you pay for, especially in the PSU market where competition is quite fierce and prices are already pretty low. I eventually picked the Delta supply as my supply of choice, after concluding that the ebay supply was a bit too dodgy for my liking, and that the Cosel was far too expensive and with somehow poor ripple performance.
Finally, the point on Power Factor Correction - just a quick note and I hope to spend some time to investigate more.
I noticed the Cosel supply does have, in-fact, a listed PFC of 0.95 (http://www.cosel.co.jp/en/products/pdf/SFE_PAA.pdf), which is very high, and it seems to me that there must be some sort of  PFC going on at least (their 100W models and higher have a PFC of 0.99). If you look at the Ebay supply, the bridge rectifier is connected directly to the bus cap, so the PFC will be pretty low for that. If you look at the Delta or TDK Lambda $20ish supplies, they don't list the PFC, but simply say that they have PFC to "EN 61000-3-2 standards", but the EN 61000-3-2 standard does not apply to supplies <75W. In the Delta supply also connects the bridge rectifier directly to the bus cap and there is nothing in front of it besides the standard coke and x / y caps, and I would expect this to have a PFC of more around 0.55 to 0.75 depending if there is passive PFC or not.
This leads me to suspect that the Cosel is indeed doing some sort of active power supply correction - it does look like this was the part which I missed out, and the supply might be doing it perhaps with the extra TO220 package (it's labeled as TR, so it seems to be some transistor) and the extra inductor/transformer and diodes I see on the board (maybe a buck boost or something). So I think I'll give this another go and see if I can answer the questions, and maybe trace the circuit.  :) This will also help explain why the 200V bus cap is a 200V cap. Then it follows that Cosel can easily use the same supply layout, tweak the voltage references and output power to make this essentially the same for their other higher power PSU lines like the 75 or 100W ones, all using the same case and same PCB, and not worry about EN 61000-3-2 PFC standards.
« Last Edit: February 27, 2015, 12:01:15 am by loneoceans »
Offline jaxbird
« Reply #40 on: February 27, 2015, 08:11:36 am »
Good work, you should consider building an electronic load for testing.
Have a look at this simple but well designed project by Jay_Diddy_B using very common and cheap components:
https://www.eevblog.com/forum/projects/dynamic-electronic-load-project/
Analog Discovery Projects: http://www.thestuffmade.com
Youtube random project videos: https://www.youtube.com/user/TheStuffMade
