Kjelt:
Hey, I'm not asking you to "shut up" ;-)
I am about as mechanical as your average software dev. I am glad of being warned here about some things.
After watching dozens of youtube videos and what people were able to do with those chinese things, reading them being called "useless" seemed unduly harsh.
Guess I have read (more than) enough of the ramblings of experienced, older pro EEs on forums, telling the kiddies who try to get into their new hobby to either spend $ $ $ $ on their gear - or die.
Slightly bemused after watching the recent discussions on how many 100 bucks to spend on a device that heats a metal rod with the mass of a penny (soldering iron with heating *inside* the tip?),
I continue to work with the 70 € hobby-Weller, with the tip I bought 2011, which doesn't look like I need to replace it anytime soon.
For some weird reason, it seems to do the job. So someone doing repair work every day may have a different experience, but I'm not that someone.
My whole setup here probably costs less than 1500€. Including the DIY workbench, lol.
Bought used, older lab PSUs, granted.
I'm not sure I'd dare to buy a used "real" CNC mill, though. Not to mention I couldn't buy a big one that is going to displease the neighbors more, I also probably couldn't tell if there's something slightly wrong immediately, and there's no warranty...
And what you spent on your machine is almost what my Hyundai car cost *new*, incl. climate control! ;-)
A more feasible option than that would be to have everything made by others, but that quickly adds up also to a high cost, with another set of drawbacks.
So I will try with the cheap stuff.
Should I learn that it really does not perform to my (not hugely high) expectations, and I do not manage to break them, I can still sell them and go other routes.
You know. To be able to get prototype front panels accurately drilled, even if it was just plastic, not aluminium, would be quite awesome. As one of many examples of the more "light uses" I'd have for that.
This would beat the hell out of me sitting at the desk with the battery drill, going hole by hole, with roughly 1mm and 5° accuracy
(no I don't have a proper drill, for critical stuff I need to visit my father, the distance is inconvenient
