I recently received a triple power supply ordered from Circuit Specialists.
It's 0-30V at 0-3amp X 2 and a 5v @3amp supply:
http://www.circuitspecialists.com/prod.itml/icOid/10338While I'm guessing it's one of the Mastech variants, I was looking for
a supply with LED displays, not LCD, because I find the LEDs to be
much more readable, especially at funny angles to the faceplate.
One of the things I liked about this supply, is that the current and
voltage are color coded. While I like shiny things as much as the
next fellow, I can tell at a glance if I'm looking at voltage or current.
The voltages are green and the current is red. Simple!
Let's look at the front panel. It's the usual assortment of 4 displays, color
coded as I mentioned, each with current and voltage controls.
In the center is a mode switch which allows each supply to run
independently, or in parallel for 0-30v up to 6 amps, or in series
to run as 0-60v up to 3 amps. Neat!
OK, let's see how well the voltage displays measure compared to my
Fluke 87-V. First we have the left and right supplies:
and now the non-adjustable 5V supply. Hmm, maybe I can find some
adjustments inside to tweak things, not that they are very far off.
Switching to amps, let's short out the supplies and see how the readings match.
Here are the left and the right:
So far so good, next I'll have to pop the cover off and see what we've got
inside. I'd do that in another post.
Scott
