Just bought my self cheap 1 HP oil less air compressor, works fine. Its just I live in a very humid place, sometimes the air humidity can reached up to >90% with average of 70-80%. After running just for 3 days just for one or two hours each, when draining the tank, the water accumulated was almost a glass.
I've been reading, watching at the net, all those air drying techniques, from running copper pipes on the wall on the tank output, up to industrial grade air dryer, and all I want is just to reduce as much as possible the water relatively cheaply. Not overly ambitious, even it can reduce <50% , I will be happy.
Thinking of using car's air condition evaporator or condenser unit + a blowing fan, as the sizes close to what I want, and to cool down the hot air from the compressor outlet, and add a cheap water trap BEFORE getting into the tank. The current setup already has the water trap on the tank output.
Locally the evaporator or condenser are relatively cheap, maybe just 20 to 30 bucks, the ones with aluminium pipes though, not copper as they're so expensive.
Question is, which is more suitable to use ? Evaporator ? As it has bigger pipes internally, compared to condenser, which has many smaller pipes which I worry the contaminants will eventually clog it.
Or any idea or suggestion ? Or maybe share your experiences ?
