So, the old outside security camera at my mum's house had a weather seal fail.
The system had been unused for a while, hence how it came to be so corroded as opposed to just corroding a little bit before the camera noticeably failed.
Rather than hunt around for the cheapest possible one from China (and wait weeks) I went and bought a replacement from a security systems shop. (The mounting base plate is removed in this pic.) Seems nice. I bench tested it, 12V in and video out, it gives a great picture.
It's a much better designed case for weather sealing than the old one, but I added some extra protection anyway. Old fashioned water pump grease in all the case penetrations, threads and seals.
It sits up on a pole on the roof, for a view of the garden and a fish pond that some neighbor lunatic has now and then vandalized in the past. For this use it has to be a day/night type, with IR flood.
After lugging all the needed gear up on the roof, began what was expected to be a quick install. The old PAL monitor was intended for setting up the camera zoom & focus. They interact, and incremental adjustment with a ladder in the loop is a pain. That plastic molding at the cable fork doesn't fit through the conduit mounting, so I'd planned to just cut it off and do a cable splice. Power first, then video temporarily to the monitor, then splicing the video too.
I was just about to cut the 'fork' off, when I noticed... what? How come this thing has a button on it? Oh, don't tell me...
The leaflet is a single sheet of paper, folded in half. I'd given the outside a very quick skim in the shop, and that seemed all fine. Now I opened it up.
The surprise inside:
Sure enough. This bloody thing has a series of multiple on-screen configuration menus. What's the bet if I just cut this 'control unit' off, later I'll find some of those config menus need to be used? Arrrgh!
What were they thinking? It's a security camera. Should have just power in and video out. In all applications it's definitely going to be mounted high up somewhere. It will have a cable to the recorder unit somewhere else. The mounting will be on a wall or something, and there's no way this plastic bit with the button control can be fitted in the camera mounting. So, once the camera is installed, pointed, etc, how is anyone supposed to get at this control button? Yet if it's to be used at all, it will need to be used after the camera is mounted.
This is one of the stupidest, most poorly thought out products I've seen for a long time. The designers seriously didn't think it through.
I'm going to be having some words with the shop sales guy tomorrow, since I did mention this would be going on a pole up on a roof. Unfortunately I already mounted the baseplate to the pole, including silastic on the foam 'weather seal', so a return & refund is unlikely.
As the mounting is now there's absolutely no space for the control part. So either I add a small weatherproof box on the back of the pole, or the control thing HAS to be cut off, and some means provided to reconnect it if needed.
Alternatively, it might be possible to run another cable back to the recorder inside the house, and wire the control thing there. If it works over that cable length.
What a pain.
