Author Topic: ENGINEER SS-02 SOLDER SUCKER review + awful service customer  (Read 23369 times)
Offline Ig_sherwoodTopic starter
« on: November 04, 2016, 05:59:18 am »
Time ago i've bought for my self this very good soldering pump made in japan for € 20.00 (circa)
This pump works really well,but the only 1 problem is :
there are no spare parts like the rubber gasket of the plunger.
When i bought this pump, i don't know about no spare parts ,so i never kept in mind that in the future i will be worried about the servicing.
I really like this pump,but i completely in disagree with the custumer service of this brand "ENGINEER ®"
I wrote an letter to the ENGINEER ® in Japan, to ask them where i can find & buy this O-ring.
The result was this :) Just enjoy ....
No comments ...   right ?
By using their logic, i must to re-buy this pump every that my O-ring will be broken ....
:horse:  :horse:  :horse:  :horse:  :horse:  :horse:  :horse:
However i really like this pump so i will enjoy it like is by now ,i also really hope to find some solution for this nasty problem ,but in meantime enjoy this teardown.
« Last Edit: December 11, 2016, 09:28:41 am by Ig_sherwood »
The following users thanked this post: Free_WiFi
Re: ENGINEER SS-02 SOLDERING review + awful service customer
« Reply #1 on: November 04, 2016, 06:25:38 am »
Pics are finally uploaded  :phew:
Remember also !!!
If you are going to buy this pump ;
BEFORE TO USE IT ,YOU MUST TO APPLY THE LUBTIFICATION GREASE INSIDE THE ENTIRE SURFACE OF THE PUMP.
« Last Edit: December 11, 2016, 09:32:29 am by Ig_sherwood »
« Reply #2 on: November 04, 2016, 06:39:41 am »
Why you need exact part number for the oring? Can't you just find a similar "compatible" oring of same thickness and same or slightly smaller diameter?
Im ready to find some other solution ,but where ?
I need an o-ring which perfectly fits the original design,because the original o-ring is not just an rubber around the metal plunger piston.
« Last Edit: December 11, 2016, 09:39:09 am by Ig_sherwood »
Offline eKretz
« Reply #3 on: November 04, 2016, 06:45:19 am »
You need some way to measure at least somewhat accurately - say a digital caliper or some such thing. Measure the diameter of the o-ring while it's installed on the piston, then remove it and measure the diameter of the ring's cross-section. The replacement should match the first or be slightly smaller and needs to match the second as exactly as possible. It is highly likely they would have used a standard sized o-ring to keep costs down. You ought to be able to find one at any reputable industrial supply company.
Offline sotos
  • Country: gr
« Reply #4 on: November 04, 2016, 06:49:49 am »
Buy a whole set they are cheap.
Here is an example of what you are looking for.
http://www.harborfreight.com/225-piece-metric-nitrile-o-ring-assortment-67609.html
You can also ask the manufacturer about the diameters.
« Last Edit: November 04, 2016, 06:51:21 am by sotos »
Offline DTJ
« Reply #5 on: November 04, 2016, 07:57:46 am »
Storm in a tea cup?
Just visit your local bearing supply place they'll probably give you a suitable O-ring for free. Between the metric & imperial sizes you'd be sure to find something suitable.
What the supplier is saying is that  for the cost and bother of shipping a $0.10 seal you may as well order a new tool.
The following users thanked this post: SeanB, Tube_Dude
Offline tautech
« Reply #6 on: November 04, 2016, 08:21:35 am »
An O-ring is the obvious solution but the pics indicate the cross section required in 2 dimensions is not round.
And even if you could find one to shoehorn in there the friction would increase as a result of the larger bearing surface.
Then your much liked sucker might not perform as well as it did.
I would try to find an auto brake seal from a master or slave cylinder for a better match of dimensions. Just be aware lube would then need to be changed to one compatible with Nitrile rubbers.
Then there's hydraulic or pneumatic ram piston seals that might also be suitable........
Avid Rabid Hobbyist.   Come visit us at EMEX Stand #1001 https://www.emex.co.nz/
The following users thanked this post: Ig_sherwood, Free_WiFi
Offline wraper
  • Country: lv
« Reply #7 on: November 04, 2016, 08:48:11 am »
By their logic, i must to re-buy this pump every time when my rubber gasket will be broken ....  :horse:  :horse:  :horse:  :horse:  :horse:  :horse:  :horse:
Do not justify them not stocking it outside the Japan, but,I guess, they are suggesting it makes no economical sense to ship it from there.
The following users thanked this post: badrequest400
Offline eKretz
« Reply #8 on: November 04, 2016, 09:13:23 am »
Good catch tautech. Missed that viewing the pics on my phone screen. If the seal ever gets damaged and proves difficult to find I'd just switch it to an o-ring with something added below it in the groove to take up the extra space (machined urethane band or split metal spacer, etc). Alternatively a new piston made to use an o-ring could be easily made as well. Then again, the seal might just last a decade or two, not being under much stress. Keep it clean and lubricated and you might never need to replace it.
I have a very similar sucker made by Ersa that uses an o-ring as the piston seal and have used it quit a bit over the last 5 or so years, keeping it regularly cleaned and lubricated with silicone grease - it shows no signs of wearing out so far.
« Last Edit: November 04, 2016, 09:19:15 am by eKretz »
Offline tautech
« Reply #9 on: November 04, 2016, 09:25:24 am »
Good catch tautech. Missed that viewing the pics on my phone screen. If the seal ever gets damaged and proves difficult to find I'd just switch it to an o-ring with something added below it in the groove to take up the extra space (machined urethane band or split metal spacer, etc). Then again, the seal might just last a decade or two, not being under much stress. Keep it clean and lubricated and you might never need to replace it.
Looks like a nice sucker though and one could be tempted to turn up a custom piston, one that takes a easily obtainable O-ring with a thin cross section in order to maintain performance similar to standard.
I think I've only cleaned my cheapy Jaycar one a few times in the ~15 years since purchased, it has a nylon piston and a ~2mm O-ring and it still performs OK with very little love and care after all that time.  :scared:
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #10 on: November 04, 2016, 09:27:52 am »
It's definitely a good looking solder sucker, certainly better than my 20 odd year old one anyway and some nice pictures provided by the OP as well, I haven't used mine in years after getting a desoldering station which seems to work pretty well for my mundane tasks.
It looks similar to a quad ring seal pictured and linked below, I would probably wait until the original seal failed completely and if all else failed then try two o-rings side by side, as tautech mentioned above after that I would be looking at making a replacement piston on the lathe that would accommodate standard and readily available o-ring seals.
http://catalog.daemar.com/viewitems/quad-rings/quad-rings-seals-2?
« Last Edit: November 04, 2016, 09:52:32 am by Muttley Snickers »
Re: ENGINEER SS-02 SOLDER SUCKER review + awful service customer
« Reply #11 on: November 04, 2016, 06:36:20 pm »
If anyone is interested about more details of the O-ring and the plunger ,there are more pics :
« Last Edit: December 11, 2016, 09:40:10 am by Ig_sherwood »
The following users thanked this post: rspt1908
Offline tautech
« Reply #12 on: November 04, 2016, 06:58:08 pm »
This one:
Looks just like a wheel slave cylinder seal to me.
Edit
@ Ig_sherwood
Do you have a micrometer?
As it's made in Japan the measurements will be metric, give us the bore dia, piston groove dia and the piston groove width and I'll see if I can find a source of the seal for you.
« Last Edit: November 04, 2016, 07:15:57 pm by tautech »
Offline stj
« Reply #13 on: November 04, 2016, 07:28:40 pm »
it's important to use the right type of material or it wont last.
Flourocarbon rubber looks like the one you need.
« Reply #14 on: November 04, 2016, 07:43:52 pm »
Edit
@ Ig_sherwood
Hi there .
Sorry but i have not the digital caliper nor the micrometer  :-//
« Last Edit: November 04, 2016, 07:47:34 pm by Ig_sherwood »
« Reply #15 on: November 04, 2016, 07:57:22 pm »
If it is a brake slave cylinder seal ( most likely) then the best lube will be a silicone based high temperature brake fluid, which will be a small 250ml bottle and which will last a lifetime as you use a drop a month on it.
It could also be a standard motor shaft seal as well, which is fine with silicone oil or mineral oil as well, and which also will last years there.
My one I replaced with 2 Orings, and it has lasted for decades, and still works with lubrication using motor oil. Orings were cheap nitrile ones, out of the box assortment. I did have to fix it after a few years of use, as the plunger trigger broke, but I made a new one using a piece of aluminium rod.
To prolong the life of the tip i also added a rubber sleeve ( salvaged from old equipment that used those Hellerman expanding sleeves on the terminals) as a seal, it makes a good flexible seal, but you can also use silicone fish tank air line for this, so long as it will survive soldering iron tip contact somewhat.
« Reply #16 on: November 04, 2016, 07:59:19 pm »
I'm not sure if i making some misunderstood with you or you with me.
Im sayin that : their custumer service is very nasty and also looks like an fraud.
Just can't believe they really want me to spend each time 20 or 30 euros ,instead to sell me the o-ring that maybe cost around 1 euro 1 pair.
Offline Delta
« Reply #17 on: November 04, 2016, 08:26:53 pm »
That is a lip seal, aka PolyPak seal.  Easily obtainable. :)
The following users thanked this post: blackfin76, amyk, Ig_sherwood, rspt1908, Free_WiFi
« Reply #18 on: November 04, 2016, 08:43:41 pm »
BINGO !!!
It's really looks like that :)
thanks you buddy .
« Last Edit: November 05, 2016, 03:08:08 am by Ig_sherwood »
Offline Delta
« Reply #19 on: November 04, 2016, 09:00:46 pm »
 :-+ No problem mate!
I took a sabbatical from electronics and worked as a heavy mechanic for a few years.  Who knew that knowledge would come in handy one day on an electronics forum!   :D
Offline P90
« Reply #20 on: November 04, 2016, 09:06:31 pm »
Don't waste time with a solder sucker.
Buy a Hakko desoldering gun and be done with it. You'll thank me later...
« Reply #21 on: December 01, 2016, 12:43:51 am »
Sorry man ,but i hate any soldering system which is not Metcal  8)
Offline Monkeh
« Reply #22 on: December 01, 2016, 03:12:17 pm »
It's so cool to be irrational.
The following users thanked this post: nikitasius, Talebe
Offline nanofrog
« Reply #23 on: December 01, 2016, 06:08:40 pm »
I've the same solder sucker, so this will be useful info for me as well.  :-+
Thanks guys.  ;D
Offline MaximRecoil
« Reply #24 on: December 01, 2016, 09:27:18 pm »
We had Metcal everything at the PCB factory I worked at, including the Metcal desoldering guns connected to an STSS or MX-500 and shop air. But everyone was also issued an Edsyn Soldapullt DS017LS. Aside from some of the old ladies on first shift, no one bothered with the desoldering guns. A typical job for the Soldapullt was desoldering 400 through-hole terminal block joints due to someone soldering in the wrong ones or soldering them in the wrong positions. That took about 10 minutes.
However, there are some situations I've encountered at home where a desoldering gun might have worked better than my Soldapullt, i.e., ancient PCBs with delicate pads; sometimes the suction from a Soldapullt is enough to suck the pad clean off the board. A desolder gun might be gentler in such cases. The PCBs at work were brand new and high quality, so the Soldapullt never harmed a pad there.
