I'm on the hunt for a USB-powered/interfaced programmer which will handle EPROMs of up to 42-pins (or even more). I don't want to spend a fortune but I also want one that's reliable and preferably has reasonable to good support from the manufacturer in the form of updates as required. A bonus would be if it also tests static RAMs and even TTL logic chips.Any recommendations please?
Support chip model:24/25/26/93 serial EEPROM, 27/28/29/36/37/39/49/50 EPROM, Paged EPROM,FLASH memory (NOR, NAND, SPI NAND, EMMC, NVRAM, SRAM, CPLD (GAL), etc.Support package: add DIP42/PLCC44/SOP44/QFP44/TSOP48/TSOP56/BGA48/BGA63/BGA64 /BGA100/BGA153/BGA162/BGA169/BGA221 on the basis of TL866II.NAND EMMC supports maximum capacity up to 256G
