Hi there i would like to know which one in your opinion is better.
Each one is ESD ok, but i don't mind a lot that.
Each one costs similar 240€.
Weller is analogic, while ersa is digital (i think analogic stations are more durable isn'it?)
Ersa has a shorter distance tip-finger
what do you think ?
I have the i-con pico. About digital vs. analog, are you afraid the electronics will break? I wouldn't be. Besides, without it you wouldn't have standby and auto-off modes. I also like that the nano/pico shows both set-temp and actual temp, because you can see how much heat escapes on joints of various sizes, which is... interesting.
Besides that I think the cable could be thinner or more flexible. I'd prefer tip-changing to be as smooth as the "hot plug" kinds that newer weller and metcal has, but they have to reserve some features for the higher end models, I guess. Main reason I bought the pico was the fast heat-up time, small light-weight pencil.
I have the Ersa i-con NANO and am very happy with it but I can't compare it with the Weller because I've never used it.
Between the two brands you've listed, I'd recommend going with the Ersa.
That said, you'd be better off with an
iCon 1V if you can manage the additional funds (backlit screen; the Nano doesn't have this, and only work with the iron that's included).
Also, if you go to Batterfly (located in Italy), they sell Hakko gear. The
FX-950 or
FX-951. Better value IMHO, and are closer to your stated budget (the FX-950 is actually under). Also, the tips are both high quality and are reasonably priced (especially as they're cartridge types). Between these two models, you get more features in the FX-951; particularly regarding set-back features.
Ersa icon nano, don't waste time with the Weller.
+1 for ERSA, I was a happy user of different old models before (anybody remembering MS8000?
) and now a very happy user of a I-Con 2V:
https://www.ersa-shop.de/index.php?cat=c873_04-i-CON-2-V-04-i-con-2-v.html Regarding I-CON 2V is not something to consider exactly annoying but the rotary encoder "push" buttton action feel is quite strange. Might be only my personal feeling about if anybody has one around and can share his/her personal feeling about will be great.
Hmm, the push button on my iCon 1 encoder feels fine to me. It has a pronounced resistance initially (which is helpful, so you don't inadvertently push it while spinning the encoder knob). Then it gives in with a "clack" sound, and can be pushed in by about half a mm. It feels very similar to the encoder buttons on my Rigol DS1054Z, and to the low-cost ALPS encoders I have used in various projects.
Same goes for my iCon 1, just about perfect. The 2 may be different or it may just be that particular encoder with a not great feel. Anybody else with a 2?
