I have bought both quick 861DA and hulko 861D+
I have tested both quick 861DA as the hulko 861D+
If have found that the ‘’ clone’ hulko 861D+ performance
Very good when u calibrate iT
I have done many repair jobs using the hulko 861D+
As for the iPhone a10 CPU removing and reballing puting
Back and the iPhone stil workig after the repair
For this station i use bent nozzles from the quick 861dw
They fit also on the hulko 861D+ dont go lower then 6 mm nozzle
Very good no difference to quick 861
what about the fact that hulko has 8A fuse and Quick has higher amp fuse?
can you post inside and outside pictures of the Quick please?
an 8A fuse is equivalent to 1840W of resistance. I have the MLINK H6 station my budget is not very high we will notice a difference if I buy the
hulko 861D + thanks.
