This has got me stumped.
Moving everything around, I have my air station in the perfect place. (Ignore the cables at the back, these will be moved before I finish)
But I need something to protect the underside of the shelf above, while the air station is cooling down (pushes air at full power when placed in stand until temp is 100 C)
All I really want is a 15cm (6") square, (around 5mm/1/4" thick) of hear resistant whatever that I can screw/glue to the underside of the shelf.
Finding such a thing is harder than I thought.
I could use a bit of a silicone mat, but I doubt there's any glue that will stick it to the wood, I suppose I could use screws, but I suspect it will sag.
I could use something like a plumbers solder mat, but that will not last a long time.
All suggestions greatly appreciated.
Many thanks
