A couple of months back, I bought a bunch of second hand power supplies off of eBay. They were Hitachi server power supplies, labelled HS1182 (2 of those) and PPD5002 (1 of those). In total it costed me like €30 for three of them including shipping, so as for monetary loss on my behalf, it wasn't so bad. In fact I believe I got an incredible deal, seeing what an equivalent power supply would cost. Now I know what people think about using computer power supplies for lab purposes, though my expectations for these things were a bit higher than your average Chinese power supply designs. The scarce documentation claims it's been designed by Hitachi's, though the casing itself claims "Shindengen Electric MFG corporation LTD, Thailand". Your guess is as good as mine who actually designed and produced these things. It is very well possible that Hitachi bought the retail rights from Shindengen Electric co. If you have more info on these things, don't hesitate to reply. As with lots of server hardware, there is no public documentation available.
I won't advertise the eBayer who sold me this (he has tons more of these second-hand industrial surplus things, it's crazy what he has for sale). All I'd like to say is that the box was nice and as for the second-hand nature I must say that it's not really that beat up. I've heard true horror stories of people buying surplus stuff online, though my experiences with surplus electronics have thus far been good.
The size of these puppies (HS1182) is, a bit strange. You'd expect them to be 19 inch due to the wide-spread usage of 19-inch racks. But the width is 26cm, or 10 inch. The front panel has two extruding metal parts and has a total width of 28.5cm. I'm not sure what's going on with these dimensions. It's about 4cm thick and 25cm long. The dimensions of the PPD5002 is even weirder (just 20cm wide, 4.5cm thick and 23cm long).
The sole reason I got these surplus devices was for their rated maximum values. Yep, it really says 12v 74a and 5v 58.8A. This is one gigantic 1kW SMPS. They're pretty specific about the input voltage and frequency (200-240v ac at 47 to 63 hz). I guess it'll work in Europe, Australia and most parts of the world that use the 220-240v system. I found it a bit weird, because it implies they have a separate model for 100-120v counties such as the USA and Japan. What's further interesting is the datecode. It says 0305 which is presumably february 2003. There's a little green led, a soft powerswitch and some pin headers on there, some with jumpers. I have no idea what the pin headers are for. If anyone knows, don't hesitate to reply.
When I opened it up, I was pleasantly surprised that there are two calibration pots for the 12v and 5v rail. According to my trusty old fluke 73, the 12v pot allows you to adjust the voltage from 11.5 to 13.7v. The 5v rail can be adjusted from 3.6v all the way up to 6v. The thing just falls short of the 13.8v automotive industry magic voltage, though I can only imagine these things to be wonderful for high-powered li-ion emulation. Of course you can do the 5v necessary for many TTL devices. I'm a bit disappointed it doesn't go down to 3v3, but alas.
This would be the big money-shot of this thread (see bottom for full-size). Notice the absolutely massive stabilizing capacitors and all the separation transformers. What I find strangest are the blue wires that are wound around those absolutely massive chokes. They're connected to points only labelled "S" and "F". I'm not sure what they do or what they're for. If anyone knows, please tell me, I'm very interested in it! Most of the chips cannot be identified because they are strongly pushed against various heatsinks. The ICs I can identify are a whole lot of KCH30a10 diodes (these are 30a diodes for rectifying the hf "AC" from the switching transformers). There's a whole load of D5L60 diodes on them (made by Shindengen). The 12v rail has 2 diodes labelled S60SC4M. The datasheet says they're Schottky-type rectifiers again made by Shindengen. there's some SIP-style devices on vertical riser boards, but they're very hard to read. One says "5332M", which I assume is some power-factor correction device. I've not yet found out how this SMPS precisely works. I can only assume that the grey square devices that are heavily held in place on the heatsinks play a major role. The grey components are about the only components producing heat. If I listen very closely to it, I hear some switching noise coming from it, though it's barely audible. On the front there's a little green led and a soft power switch, implying there is some control circuitry that controls the on/off state.
The last thing I'd like to note is that, as with many power supplies, it's not always "on". There's a soft power switch on the front of this device, but it doesn't switch the power supply on unless there's two pins connected on the back side. I guess this prevents the PSU from wasting electricity when the servers aren't switched on, or something like that. I have some experienced with these Hitachi PSUs; switching them on usually meant connecting one of the pins to the 12v anode (12v and 5v rail do NOT share anodes). It usually only takes a couple of minutes before you hear a loud click from a relay. The very obvious down-side of this thing are the strange AMP/molex connectors. I don't have any connectors that even remotely resemble these things, nor do I have any information on where to get them. If anyone knows more on these exotic molex connectors, please tell me! I usually just stick breadboard cables in them, they hold quite firm. There's no way I could use the full 58/74A through breadboard cables, though. I was seriously considering desoldering the AMP connectors and soldering on something else with a decent standard connector, not like these things have much value anymore.
Although I'm not going to use these things to power up any servers or harddrives, I'm overall very pleased with the solid-steel construction and engineering quality that has gone into this thing. It's too bad I have to bodge the thing with a little red wire to boot it up, but apart from that there wasn't anything bad inside that I could see! Anyway, this is all what I wanted to write. If you want more pictures or just discuss this: a reply is just a click away!
