I resoldered both STM32F103 to their boards. Both devices were working as expected with original firmwares and RDP still on.
I used the JLink to disable RDP and to programm the Jabe UD-1200 PRO first. Quite easy with the 2x10 pinheader.
openocd -f interface/jlink.cfg -c "transport select swd" -f target/stm32f1x.cfg
(and in another terminal)
telnet localhost 4444
init
reset halt
stm32f1x unlock 0
reset run
init
reset halt
flash write_image erase /...[...].../Jabe-UD1200-128k.bin 0x8000000
reset run
exit
After that, the device turned on and showed only the welcome screen. System doesn't start up. I tried all combinations on the buttons while starting the device, without success.
I then tried to flash quick and dirty the eeprom in the PRO version with data from non-PRO Version using a pomona clamp. Unfortunately, this didn't work.
I had to desolder the eeprom and programm with adapter instead of the easy way using a pomona clamp.
The PRO then started, and i had english language.
But i couldn't use the OK button. The OK button did the same as the down button. I was not able to use the menu. After reflashing both, eeprom and STM32f103 the PRO startet and i was able to use the OK button to use the menu. Picking up the T245 handle i could change temp. To my surprise, the device had the same temp limit on the tip like i had with the original firmware when using a T245 handle. Remember, the PRO came with T210 handle.
So far, no luck with my idea just swapping the firmware and use the PRO with a T245 handle.
The UD1200 non-PRO was my next victim. While the PRO showed me the welcome screen after flashing, the UD-1200 did nothing.
Usually there is a beep when turning on the device. It was just dead. I also desoldered the eeprom like i did on the PRO. I programmed the eeprom with data from PRO eeprom.
After that, the non-PRO device turned on and showed me the welcome screen but failed to start the system. The PRO firmware does not work on the non-PRO device. I reflashed the non-PRO firmware (while the eeprom still had it's data from PRO version) and the device starts as expected. Temperature on display matches the temp on the tip.
The only thing was, the counter had zeros.
Flashing is very easy once the RDP is turned off.
If there is any brave UD-1200 owner with a newer firmware that supports the three temperature presets and is willing to extract the firmware and eeprom content please contact me.
