Hi all,
I have a spare power supply board and want to replace the three main caps. The 400V 82uf and the two 1000uf 35v caps. I have a Nichicon 400V 82uf cap at 105C (o issue with these) and two Rubycon caps at 1000uf 35v, however, these two are 85C caps. The ones on the board (even though junk caps) are rated at 105C. Could I use the 85C Rubycons in this unit?
Thanks for any insight.
