Author Topic: Low cost ( chinese ) Plasma Cutter / TIG welder Combo suggestions?  (Read 9102 times)
Offline mrpacketheadTopic starter
  • D Size Cell
Probably not a typical electronics tool, but this community has wide interests and expereinces so worth a try.
I'm wanting to buy a low cost TIG / Plasma cutter combo. Ideally spend less than $1000.     Its not going to get lots of use, I'm doing a container building job, so have a bit of cutting and some welding to do, and thought i'd just buy the tools.     I've seen several models that are beign resold in NZ that are chinese imports, but i figure i can probably save a bunch of cash by buying it myself.
Does anyone have any suggestions.
  • D Size Cell
Re: Low cost ( chinese ) Plasma Cutter / TIG welder Combo suggestions?
« Reply #1 on: August 14, 2018, 03:52:41 am »
Call a tradesman, pay $50/hour, and get him to get it done for you.
If it's a one off job, it's almost always cheaper to out source than to buy-learn-do-retry.
Thanks, but i actually want to do it myself.  If i had used that mentality for every skill and bit of gear i did'nt have, i'd have done nearly nothign.      Plus you won't get a 'tradie' in NZ for $50.  You'd be lucky if you can get them for $100 and you'd have to wait 6-9 months.
Offline Mr.B
« Reply #2 on: August 14, 2018, 04:36:13 am »
...You'd be lucky if you can get them for $100 and you'd have to wait 6-9 months.
Yip.
A Plumbing company here in Nelson that shall remain unnamed want $450 for a call-out, plus $155 per hour.
Their definition of a call-out is "Sometime in the next 7 days".
All of the trades are so busy in NZ at the moment and some can demand any price they want.
DIY mrpackethead... Agree with you that is the way to go.
I approach the thinking of all of my posts using AI in the first instance. (Awkward Irregularity)
The following users thanked this post: mrpackethead
Online BradC
« Reply #3 on: August 14, 2018, 05:51:53 am »
Wow, I'd typed up a huge wall of text detailing my experience, but checking E-bay they have gone up massively in the last 5 years, so no. Nothing I have is relevant to the <$1000 bracket although all my TIG/Arc/Plasma units were significantly less than that at the time.
Offline KL27x
« Reply #4 on: August 14, 2018, 06:06:52 am »
Are you asking about ordering things on Alibaba? A lot of members probably have some advice on what to look for and what questions to ask a seller; maybe you'd get more hits if you worded the thread, differently. If you wanted advice about specific machines (not that I have any), it might help if you included the scale of the job. Thickness of steel, size of the containers, and what quantities. I'll be curious to see suggestions, myself, and your impressions on w/e you end up buying/using. I have been on the verge of buying a stick/TIG for awhile, now, for absolutely no reason, doing essentially no research, lol. Had one in my online cart more than once, but I chickened out.
Offline CatalinaWOW
« Reply #5 on: August 14, 2018, 06:14:37 am »
Don't know if this has any bearing on Southern hemisphere prices, but my son did a lot of research recently and concluded he couldn't get a decent set for under $1000.  He ended up getting an Everlast unit and is very happy with it, but it cost nearly $1400 on sale.  Both he and I know people who have the even lower cost units and all have had some level of dissatisfaction.  That $1400 doesn't include other necessary expenses like helmets, gloves, tips, rods, gas bottles and wire.  Count on another couple of hundred for those items.
I agree with you, it is often cheaper to buy than to hire.  There really are very few one off jobs, another use pops up periodically.  Sometimes annually, sometimes more often and rarely much less often.  If nothing else the "If you have a hammer, everything looks like a nail." syndrome sets in.  You also get to control schedule and quality which is often worth quite a bit.  Throw in the fun of learning and it just works.
Online TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #6 on: August 14, 2018, 06:53:06 am »
When it comes to welding and cutting equipment, the term 'you get what you pay for' really does apply. There's only so much cost cutting that can be done to MOSFETS/IGBT's, transformers, and heat sinks before you adversely affect performance and reliability. You can't abstract out the cost of bulk iron, aluminium and copper etc like the price drops of computer parts etc with age.
Metal and silicon costs money. Less cost, less stuff inside the box.....
In my years of time fixing this stuff when I was back in Australia, I've seen lots of Chinese crap, and also some surprisingly well made Chinese stuff too.
The best bit of advice I can give if you are looking at Chinese made gear is to make certain that your supplier can supply spare parts. Things like control boards, IGBT/MOSFET modules, etc.
There are a lot of sellers out there that just sell a branded unit bought in a bulk shipment with practically no after-sales support (You wouldn't believe how many variations on the common 200 AC/DC TIG unit I've seen..) if you can't get a replacement board for your unit, you may as well use it as a boat anchor.
You may see 20 other brands of welder that look like yours, but the are almost all subtly different enough inside that mixing and matching parts from another seller can be difficult at best or impossible at worst. Many Chinese units are made to the end sellers specifications, so things often get changed slightly on the internals.
I started taking photos of the units I was fixing, I think I got to at least 15 variants of the common box shaped 200 AC/DC TIG welder, they all were very similar inside but only a few actually had cross compatible parts.
(I remember one rare case where it turned out our own house brand of part fit a customers welder, it turned out cheaper in the end and had extra output transformers and IGBT's in the switch mode output board. A rare case of more for less :D )
Basically, make sure to buy from a seller with a bit of repute behind them. Many of the Chinese units these days (besides the lowest of low end) actually work relatively ok compared with 10 years ago. When I started in the game, Chinese stuff was completely barely useable crap, but they improved surprisingly quickly to become a viable product for the small time user. The difference is mainly in the MTBF and features (depending how much you spend on the Chinese unit) compared with a name brand unit.
As long as you don't expect the quality and longevity of an ESAB, Cigweld or Lincoln Electric, the Chinese units can be great for a home or small workshop.
The first upgrade I would suggest if you do buy one is to replace the torch/hand piece with a Binzel or Tweco or similar type. Much better quality and much easier to get consumable parts.
My advice would be to look at second hand or refurbished name brand units, if you get a decent Lincoln, Kemppi, ESAB, Cigweld, etc, it'll last you decades.
If nothing turns up, then look at the Chinese units, but don't buy the cheapest one you can get, you'll regret it.....
  • D Size Cell
« Reply #7 on: August 14, 2018, 08:28:55 am »
^^ This is very true for most stuff. I am regularrly buying thigns from China, and i'd say i get it right 9 out 10 times.  I've bought a Mill,  Laser cutter,  and other stuff thats been great. I buy componetns and PCBs every week.   Its all about doing your homework.
This communtiy is great.. You get lots of good feedback. ( even feedback thats off topic is helpful )
  • D Size Cell
« Reply #8 on: August 14, 2018, 08:29:45 am »
Im not adverse to spending more if i have to.
  • D Size Cell
« Reply #9 on: August 14, 2018, 08:33:40 am »
Ideally Id love to hear from people have already bought one, and have got warnings or priase about it.
My first job. I have three 40' shipping containers to deal with.   I've got to cut one side out of two and two sides out of the third. ( they are going to be stuck side by side ).. I'll have to weld in place some longer I sections above the cut out sections so the container does not warp.     Container steel is typically 2.5mm thick.   the alternatives to Plasma are to use a gas torch. but that is hard to get really nice, or an angle grinder, with cut off blades.  ( easy, cheap enough, but hugely tiem consuming and very hard on the old arms )
Online BradC
« Reply #10 on: August 14, 2018, 09:11:43 am »
All 3 of mine were bought through E-bay.
I bought unit 1 to learn to TIG weld by welding up the alloy head for my car. Or, to re-arrange that, I needed the head in my car welded up and decided to buy a welder and do it myself. Guy at the welding shop called me a nutcase but sold me the rods I needed. Asked me if I'd ever welded (no) and what welder I intended to use (E-bay 200A cheapie). Then asked me (while laughing) to come back and show him photos of what was left.
Welded up the head, faced it on my neighbors mill and took it back to the shop. He's taken me seriously ever since.
Welder 1 was a 200A AC/DC TIG/MMA/Plasma. It came with a TIG torch (26 series air cooled - they pretty much all are a variant of that), MMA electrode holder, Plasma torch, Argon regulator and foot pedal. It was good for the head, but I wanted to do a lot of small stuff and it only went down to 20A, so I traded it to my neighbour in exchange for a larger air compressor. The Plasma was a scratch start and I had issues getting it reliably started on grungy metal. I did a lot of work with that welder over a couple of years.
Welder 2 was a mistake. I literally bought the wrong unit (wanting a replacement for my original) in that it doesn't do AC and was only rated to ~150A. Scratch start Plasma, no foot pedal. I've kept it as it comes in handy having a separate plasma when I'm doing a lot of cut & weld stuff. I really have no idea what I'd taken or drunk when I pressed that "buy it now" button, but it took me a couple of hours to figure out what I'd done and the figure out how I was going to hide it from my wife (You bought WHAT??).
Welder 3 was the winner. Essentially the same as welder 1. 200A AC/DC TIG/MMA/Plasma. Same features except this one goes down to 5A and has a pilot-arc start on the Plasma. Now I never have issues with starts. I feel like Darth Vader with a lightsabre, it just cuts anything conductive. Being able to really crank the current down comes in handy when doing things like building up a corroded portion of 8mm water pump shaft with minimal warping.
I did buy an auto-dark helmet with a huge window (locally, don't think I'd trust by eyes to an E-bay store) and I eventually spent a significant amount of coin on a small air-cooled C&K TIG torch with pyrex cups and a supple leather hose shield. I can honestly say when doing small/tiny work or spending quite a period of time at the coalface, a light and ergonomic torch is bliss. By small/tiny I mean things like aluminium cans or razor blades. Good practice for shaft buildup or work where you want minimal heat.
The C&K has a really cool swivelling head and I've used that up under the car when I wanted to get some locallised heat onto a hard to reach bolt and didn't want to risk busting out the oxy.
I can't find any direct links on e-bay to compare them to, but at the time it was a case of "not the cheapest, but near enough with the right features". And I didn't know what features I really wanted until after I'd spent time with Welder No 1 (down to 5A and Pilot Arc on the Plasma). I still use No 1 when my neighbor wants stuff welded up and I'm out of Argon. I just made an adapter for my little torch.
Get an Argon regulator with a proper flow-meter.
Torch : http://www.ckworldwide.com/130-150-amps-flex-loc%e2%84%a2.html
Consumables : http://www.ckworldwide.com/standard-kits.html with the pyrex cup they are awesome for visibility. If you spatter the cup by dipping the electrode, a nitric acid bath cleans it right up.
Helmet : https://www.machineryhouse.com.au/W003
For an absolute beginner, a foot pedal makes TIG welding a lot like soldering. I found it much easier to control the weld with the pedal while I learned torch control. Now I can do it with the on/off trigger, but I prefer the pedal if it's handy.
The torches that come with the E-bay welders are ok. I have a bucket full of consumables (again E-bay) and for bigger stuff I still use them. I'd been welding a few years with those before I treated myself to the C&K. The gas-lens consumables are available from BOC (over here anyway). When I bought the consumables I bought a stack of lanthanated electrodes. I'm still on those. If you learn to keep them out of the weld they actually last really well. I'm a slow learner.
Aside from welding, carbon rods make great arc-heaters. The TIG is useful for brazing and silver soldering tiny things and a set of good earth leads make great jumper cables.
I'm still not a welders arsehole, but it's nice to be able to patch machining errors, seal up a cracked casting (or leaky Ducati aluminium radiator tank) and cut the top out of 44 Gallon drums without breaking out the grinder. If I'd listened to that "yeah pay someone else to do it for $50" dude, I'd have missed out on a stack of fun stuff (and quite a bit of on-the-side work).
The following users thanked this post: mrpackethead, KL27x
Offline The Soulman
  • The sky is the limit!
« Reply #11 on: August 14, 2018, 09:54:15 am »
You sure you want to TIG weld together shipping containers?
Imho Mig is the better option or if you want to minimize the initial investment MMA (stick electrode) is more appropriate.
Offline KL27x
« Reply #12 on: August 14, 2018, 09:58:18 am »
I would ordinarily think that's hilarious. But the last few months of watching Youtube's recommended welding videos has made me feel like many professional welders are delusional about how rare their skills are. I mean, you learn from experience, but it isn't exactly juggling while riding a unicycle. It's probably just Youtube... but maybe it's the fumes? That and palpable disdain for anything not Lincoln or Hobart.
The damnedest thing.. watched a guy review a $100 welder, and he was stunned when he burned through rod after rod without overheating the unit. So then he complained that the display didn't feel like it was calibrated, correctly, putting out more amps than indicated. Total junk!  :-//
I have a professional welder in the extended fam. Whenever it comes up that she's a professional welder, she makes a point that she's not just a welder. She's a MIG welder! (Best for sheet metal, but otherwise isn't that the most limited and easiest of the bunch? :-//)
« Last Edit: August 14, 2018, 10:24:51 am by KL27x »
  • D Size Cell
« Reply #13 on: August 14, 2018, 10:17:02 am »
But the last few months of watching Youtube's recommended welding videos has made me feel like many professional welders are delusional about how rare their skills are. It's probably just Youtube... but maybe it's the fumes? That and palpable disdain for anything not Lincoln or Hobart.
Yeah, theres an aweful lot of brand biggots.
« Reply #14 on: August 14, 2018, 10:21:10 am »
Yep, TIG is the wrong choice for a big job like containers,
Both TIG and MIG can be a PITA for outdoors usage but MIG would be my choice for shipping container mods when the weather conditions cooperate. You can mitigate conditions with gas-less wire and if things are really bad use CO2 as well as it's cheaper than the argon mixes.
A 150-180A MIG will eat 2.5mm panel but if you drop too low in the choice of Amps you'll have to run 0.6mm wire. (solid, not gas-less)
Mig will be the best choice as containers are made from HT Corten steel and MIG produces HT welds.
Avid Rabid Hobbyist
Online BradC
« Reply #15 on: August 14, 2018, 10:21:18 am »
I would ordinarily think that's hilarious. But the last few months of watching Youtube's recommended welding videos has made me feel like many professional welders are delusional about how rare their skills are. It's probably just Youtube... but maybe it's the fumes? That and palpable disdain for anything not Lincoln or Hobart.
I dunno. My neighbour is a fitter & machinist who has also done huge amounts of coded and inspected welding. He's an absolute artist. He gets me to do the fiddly TIG stuff and I get him to do anything structural. The level of skill difference is many years of practice and I recognise, admire and learn from that. He's also a great teacher, so I've lucked out big time there. I did teach myself to TIG though before I started asking questions.
Most of the "professional" welders I've seen on YouTube probably sit midway in the spectrum. The really good ones can make a good weld with 2 car batteries, a length of coat hanger wire and some 3.2mm 6010 rods and while they value good gear, don't dump on the utility of the affordable stuff. But then they are few and very far between because most of them are too busy working to be recording video.
 I do rate Jody at WeldingTipsAndTricks though.
Offline KL27x
« Reply #16 on: August 14, 2018, 10:41:05 am »
No doubt there is knowledge and skill at work. If you have just one chance to get it right or people die, then you better have the thinking cap on. But as you say, just being able to do basic welds with basic equipment seems like it would be plenty useful for the average joe. My brother taught himself to weld for fun... and he's just a lowly doctor. You'd think from some of these vids you need a toolchest covered in Snap-On stickers to hold a torch, correctly.
Online BradC
« Reply #17 on: August 14, 2018, 10:49:15 am »
...you'd think you need a 3458a to check an AA battery...
It's not just welders ;)
The following users thanked this post: KL27x, sokoloff
  • D Size Cell
« Reply #18 on: August 14, 2018, 10:58:01 am »
Yeah, skilla nd experience.  Its taken me several years to be able to repeatably be able to produce error free PCB's off my PNP line. I'm not saying that welding is all hard.
The main thing i wanted to mo was use the plasma to cut the containers with.    I might be better to just buy a plasma cutter unit. They certainly are not super expensive.
I'm a newbie to welding, and did appreciate the note about MIG vs TIG.
The combo units all seem to be plasma + TIG...
MIG woudl be a better choice in deed.
Offline SparkyFX
« Reply #19 on: August 14, 2018, 11:05:08 am »
I learned some welding 20 years ago at school (not certified), but after watching probably most of the welding channels on youtube and collecting some problems at hand that can be done by welding, a couple of weeks ago i bought a relatively modern 200A AC/DC pulsed TIG/MMA/Plasma machine with a 5 year warranty on the machine itself and a pedal. Chinese manufacturer, german brand distributor. Also bought the safety gear (jacket, gloves, auto darkening helmet, welding blanket) and exchanged the gas cooled torch against a flexible one (several types are compatible), plus a gas lens kit. Some quick connectors for the gas were useful, as the machine only has one inlet for pressurized air and argon. Price range for all of it roundabout 1400 Euro.
I already finished a few little things here and there, the learning curve is quite steep and it was fun to learn. For aluminum the pedal was really important to adjust the current while you go and not screw stuff up, blow holes into the material and control the puddle, the hotter the parts get the less current is needed to melt - or just pre-heat.
If you want to cut and weld containers we are talking about steel sheet metal and a bit square tubing, maybe working on a ladder on some distance away from the power. I don´t get why you would want TIG, as your job sounds right for MMA or MIG anyway - with MIG you could use shielded flux wire and therefore work without gas, as you do with stick. You can even work one-handed, which in this case is a huge advantage over TIG. Most TIG machines do come with MMA, but a MMA/Plasma combo is probably cheaper. If you already know the maximum thickness to weld, you might even get away with a lower amperage requirement (160A for up to 4mm?!).
I don´t know how you want to weld these together, but when running beads on sheet metal always take the shrinkage into account, otherwise it might deform drastically or simply crack. The grinder will still be your best friend, as you need to bevel thicker materials to really have penetration down to the root of a joint.
My advice for buying a machine:
- if you never want to weld aluminum, you can skip machines with AC completely, it will drop the price significantly
- check the inrush current to match your power supply (in my case i got a single phase 230V, slow 16A B-characteristic breaker, that works fine even under full load), the cheaper models have the tendency to pop the breaker, maybe you could use an inrush current limiter or have access to good three phase power
- check which duty cycle you get, a 20% rating means out of 10 minutes, you can operate it 2 minutes and need 8 minutes cooldown, the higher the better, may also mean it is more reliable in the lower ranges
- check for DINSE connectors (cylindrical with a notch) on the machine, or at least one that is useful, so you can replace the cable package with a longer one
- check minimum current setting as mentioned by BradC, should you want to work with finer gage sheet metal (rule of thumb for steel: 40A/1 mm for welding)
- for TIG you might want the amperage control next to the place you weld, so for working on a ladder you should consider a torch with control included in the torch
- a pulse machine helps controlling how much heat goes into the part, but the helmet should be able to work with it (helmet delay > maximum pulse off duration ... so you don´t flash yourself at the restart)
- the TIG torches are mostly compatible to the consumables you can find on ebay (for compatibility watch this: www.youtube.com/watch?v=3KroGM5e1dE)
- the plasma torches that come with it use pretty much standard consumables
- pressurized air supply should be sufficient (in my case 4.5 bar, 80 litres/minute)
- a 50A plasma cutter is rated for 12mm thick construction steel
for the actual job i´d say:
- practice various positions you will need to do (e.g. vertical up welding) with test pieces to find settings that work for you as much as you can before you start
- practice open root welding
- practice, practice, practice
- stay away from critical, potentially dangerous stuff, anything that people walk on or under
Really good channels for welding are ChuckE2009, weldingtipsandtricks, weld.com, the Fabrication series, This Old Tony and all i forgot. They all cover some aspects, but of course do not replace practice.
« Last Edit: August 14, 2018, 11:09:15 am by SparkyFX »
Support your local planet.
Offline KL27x
« Reply #20 on: August 14, 2018, 11:17:17 am »
I'll bow out and try to learn something. Gonna definitely check out Jody and some of ^ those I haven't seen before. This is a great thread, already.
Mr.Packethead, good luck. I was envious until you described the job in more detail. Now it sounds way too much like work!
Offline mzzj
« Reply #21 on: August 14, 2018, 11:30:47 am »
Bought cheap AC/DC TIG/MMA machine 2 or 3 years ago from Germany (Stahlwerk brand, chinese made), had intermitted issues of not working at all. Checked all the connectors inside as it seem to be common problem with these, no improvement.
Pulled out the biggest control board and found dozen of ugly solder joints, including one place where pads were bridged with solder splashes. After giving the board a overhaul the machine has been working fine.  >:D
Perfect hobby machine  :-DD
Some pretty horrible looking solder joints and PCB was somehow funny, all the vias were bubbling during soldering..
 Stahlwerk has supposedly OK-working 5 year warranty but it was easier and faster to fix the damn machine by myself vs shipping back to Germany.
From what I have heard the chinese combo machines have been less reliable vs if you buy separate plasma cutter and welder.
« Last Edit: August 14, 2018, 11:34:29 am by mzzj »
Offline mzzj
« Reply #22 on: August 14, 2018, 11:33:50 am »
Can't stand ChuckE2009 as for last couple of years he has been concentrating on blatant sponsor product advertising  :(
Offline SparkyFX
« Reply #23 on: August 14, 2018, 02:49:17 pm »
Yep, that brand. Read similar stories about them, though. At least they now wrote on the website to do testing before shipping so delivery time is a few days more. Mine worked fine so far, have not yet tested MMA or the plasma torch. Similar looking machines are also available without branding, maybe the OP can get a hand on those.
There are higher quality german or european made brands, but for my occasional use not worth double or triple the money. It would be different if i worked in a commercial environment with it, need to transport it often or work in wet weather conditions. Which is why i would recommend watching those channels, they tend to point out the differences.
If available space or other requirements are not an issue, take separate machines, i´d say too.
If it floats the boat... i got no problem with that, i watch these channels (completely free of charge) to learn something and i am rarely disappointed -  even if - i had at least some english vocabulary training and feel entertained :-). I understand that it kind of decreases authenticity (which i value high), but that was not guaranteed in the first place by anyone, it is an assumption on the side of the viewer. People do make mistakes anyway, so as even there is no guarantee for factually correct content and absolute authenticity (try doing that as an individual), the sponsored content vanishes in the noise anyway.
Remember this is not straight journalism, it is people that make and edit videos and create content.
« Last Edit: August 15, 2018, 08:21:31 am by SparkyFX »
Offline CatalinaWOW
« Reply #24 on: August 14, 2018, 02:56:51 pm »
I am an amateur welder, and my welds show it.  There is no substitute for the knowledge and experience (and native capability) of a good welder.   But equipment makes a difference also.  The quality of my welds made a huge jump when I made the step to a better grade autodarkening helmet.  Being able to see what you are doing matters.  Same applies to other parts of the process.
