Hello,
I own a Minipro TL866CS for quite a while and I mainly use it to program EPROMs and EEPROMs (2732/28C64) and so far never had any major issues using it.
Recently I decided to pull the trigger on the model TL866 II Plus (Now re-branded to XGecu TL866II Plus)
I downloaded the latest version of the Windows software and the firmware was upgraded to the latest one which I believe is v04.2.132.
With the new programmer I'm having issues programming the very same ST M2732A EPROM chips that I programmed so many times with the TL866CS.
I usually use the programmer under linux with the 'minipro' software so here's the output of both:
TL866CS
$ minipro -p M2732A@DIP24 -w test.bin
Found TL866CS 03.2.86 (0x256)
VPP=21V, VDD=5V, VCC=5V, Pulse=500us
Writing Code... 5.26Sec OK
Reading Code... 0.14Sec OK
Verification OK
TL866 II Plus
Found TL866II+ 04.2.132 (0x284)
VPP=18V, VDD=5.5V, VCC=5V, Pulse=500us
Writing Code... 0%
Verification failed at address 0x0000: File=0x06, Device=0xFF
Also worth to mention that under the Windows software I have the same issue. I never tested programming the chips with the firmware that came with XGecu TL866II Plus so I really can't confirm if it would work or not (it was only a few minor versions below).
Thanks in advance.
H.
