Single and Double Arm Boom Stands can come in various materials and configurations.
For example, among others, AmScope offers "SAW" and "DAW" (there are also black versions of each):
https://amscope.com/products/saw3" (76mm) Holder Ring
23" Overall Length.
16" Single Arm.
15" High Pillar
9" x 9" x 1-3/4" Solid Cast Steel Base
40 lbs in Weight
https://amscope.com/products/daw3" (76mm) Holder Ring
30" Overall Length
20" Double Arms
17" High Pillar
10-1/4" x 8-1/4" x 2-0" Solid Cast Steel Base
Shipping Weight: 55 lbs
While I happen to use the DAW and find it very flexible as well as highly stable, the SAW looks very substantial and per HobGoblyn it also provides stable viewing. I think issues with stability might be due to products that use stands/bases, tubes/arms, fittings, and controls that are less substantial.
