It has been pulled from an Austron unit.
The OCXO has the following printed on it (see pict):
Bliley
NV92A721
10Mhz
12512169
SN 006
9703
Any info would be appreciated , but the Pinout (and supply+efc specs) of the "round ocxo" plug is the most important part.
TIA
/Bingo
Since you've got the board it was connected to, you should be able to reverse engineer the connections without too much trouble.
Serial number 006?? Obviously a big seller. Maybe that's why it never made it to the Bliley web site. The closest I could find is NV93. I know that 'N' means it's an OCXO and 'V' means it has EFC. I don't know if the numbers have any special significance.
I can't believe that Austron would use a chassis mount 9 pin tube socket and just stick wires on it like that. Seems bizarre!
Ed
Ed
@Ed
I might end up doing that , trace the lines.
But i'd have to trace the power lines first , as the unit was defect upon receipt.
And the backplane/psu doesn't work.
/Bingo
Seems like i'll have to trace it.
The mails to info@.... are undeliverable
/Bingo
