Don't get a Chinese all in one, if something dies or you upgrade you will regret it. Most of them are also knockoffs of Hakkos 907 iron. Cartridge based soldering handpieces are faster heating and easier to swap tips for rework.
A Vacuum desoldering station isn't entirely necessary, but it saves a bunch of time. You don't need tweezers (also a desoldering tool) unless you are doing very repetitive work. In many cases repairs are only a few components. Tweezers mostly save time removing multi leg packages, they are not cheap to setup either.
