You need to read up on how activated charcoal is used and how it works. Also apply some common sense.
Also, activated charcoal however its used (it also is useful orally for some kinds of poisoning) never could eliminate everything. The crucial questions here are "are 'toxic gases' present in solder fumes, if so, what are they?
Then we have to ask, does activated charcoal remove those gases if they are there?
If yes, then How much activated charcoal is needed and how does it work,
Then how much of this toxic gas can it remove and for how long under what conditions"
Then we have to ask what happens when it can no longer aDsorb whatever it adsorbs. (note the "D") and "what happens then to these substances, are they permanently attached to the carbon?
Its not a simple thing.. especially when peoples lives are at stake.
The simple answer here is, apart from acting as a prefilter to keep big particles - visible dust out of the pleats of a HEPA filter, the use of activated charcoal in (every single non-industrial air cleaner I have seen to date) is basically for show and not likely to remove toxic chemicals except at the very beginning after its unwrapped..
because of how those cleaners are designed and the amount of carbon present is just not enough, it wont last for long because there is a lot of stuff in our air that is not toxic but still will get 'adsorbed" ruining the ability of the tiny amount of activated charcoal there to work. Its still useful though, to keep big stuff out of the HEPA filter making it last much longer. Any kind of mesh or net or cloth would do that.
Look at activated charcoal filters for industrial applications and you will immediately see what I mean. Also, you'll see that they are replaced quite frequently. Failure to do that will endanger lives. Don't take my word for it, ask people who use them. Ask your regulatory agency that regulates industrial safety.
Definition of adsorption
:the adhesion in an extremely thin layer of molecules (as of gases, solutes, or liquids) to the surfaces of solid bodies or liquids with which they are in contact — compare absorption
— adsorptive play \-?s?rp-tiv, -?z?rp-\ adjective
They suck the fumes away but the activated charcoal is invariably just there for show and doesn't really function to remove any toxic fumes after the very beginning.
A HEPA air cleaner works as well or better at what they do, as far as particles go, and filters are better and cost less.
However, HEPA air cleaning works best when its allowed to refilter the air in a room or building over and over and is left on all the time.
Sorry, but you wrote a piece of complete garbage. HEPA filter filters out only small particles but lets all toxic gases through https://en.wikipedia.org/wiki/HEPA. Charcoal is what absorbs toxic gases. https://science.howstuffworks.com/gas-mask2.htm
A chemical threat needs a different approach, because chemicals come as mists or vapors that are largely immune to particulate filtration. The most common approach with any organic chemical (whether it be paint fumes or a nerve toxin like Sarin) is activated charcoal.
Yes, but...
Which Activated Carbon Should I Use?
The first decision for using carbon is to treat a liquid or vapor stream. Air is best treated using large particles of carbon to reduce the pressure drop through the bed. Smaller particles are used with liquid applications to reduce the distance the chemicals have to travel to be adsorbed inside the carbon. Whether your project treats vapor or liquid, there are different sized carbon particles available. There are all different substrates such as coal or coconut shell base carbon to consider. Talk to a General Carbon representative to get the best product for your job.
How Do I Use Activated Carbon?Carbon is typically used in a column contactor. The columns are called adsorbers and are designed specifically for air and water. The design is engineered for loading (amount of fluid per area cross section), contact time (a minimum contact time is needed to insure required removal) and pressure drop through the adsorber (needed to size container pressure rating and fan/pump design rating). The standard General Carbon adsorbers are pre-engineered to meet all of the requirements for good adsorber design. We can also design special designs for applications outside the normal range.How Long Does Activated Carbon Last?Carbons capacity for chemicals depends on many things. The molecular weight of the chemical being removed, the concentration of the chemical in the stream being treated, other chemicals in the treated stream, operating temperature of the system and polarity of the chemicals being removed all affect the life of a carbon bed. Your General Carbon representative will be able to provide you with an expected operating life based on the amounts and chemicals in your stream.Does Activated Carbon Absorb or Adsorb?
Activated carbon adsorbs. The chemical process of absorption is commonly compared to a sponge soaking up water. The water is fully integrated into the sponge, not being limited to the surface area. Differently, adsorption is a process whereby molecules stick to the surface area only. As mentioned above, activated carbon has a large surface area due to being a porous material. The unwanted substance sticks to the surface area of the carbon particles.
Which Carbon filter is best for me?
There are several kinds of activated carbon filters and determining which filter will work best for you is actually not that complicated. If you would like to learn more about the proper treatment of your application, our technicians are more than willing to find a solution. Please contact us for more information through this process.
http://www.generalcarbon.com/facts-about-activated-carbon/activated-carbon-faq/
