Author Topic: Source for used semi-rigid coax with SMA (odd ends)?  (Read 2120 times)
Offline cdevTopic starter
« on: January 27, 2016, 04:06:54 pm »
I want to make some small projects like probes and loops, etc, that really need to be made with semi-rigid coax to not be totally half assed, but its always been my perception that getting into semi-rigid is expensive.
But I am not some kind of scientist looking for absolute perfection. I am not looking to do work with microwaves presently or need the absolute best performance, I just want to be able to make some small antennas and pickup loops that aren't floppy for picking up EMI, experimenting with RF and so on.
Is there any place I can buy maybe used or surplus odds and ends of semi-rigid using cables? Other people's garbage.
Typically they will be short and only one end is going to need the connector.
Offline retrolefty
Re: Source for used semi-rigid coax with SMA (odd ends)?
« Reply #2 on: January 27, 2016, 11:38:37 pm »
Have you checked E-bay?
http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&LH_BIN=1&_nkw=semi-rigid+coax&_sop=10
Awesome - thank you!!! problem solved.
No, I had not seen that the last time I went looking for coax on ebay. Which was a long time ago.
Offline Stray Electron
« Reply #3 on: February 05, 2016, 03:30:43 am »
   A LOT of stuff like that shows up at hamfests around here.  I have a whole tote bin full.
« Reply #4 on: February 05, 2016, 05:44:34 pm »
Thank you!  That's good to know.
Offline uncle_bob
« Reply #5 on: February 05, 2016, 06:19:00 pm »
Hi
A lot of it shows up *inside* gear abandoned at the end of ham fests. Grabbing old gear and salvaging the parts is a very cost effective way to do some of this.
Bob
Offline KJDS
    • my website holding page
« Reply #6 on: February 05, 2016, 06:36:01 pm »
be careful with some of the Chinese SMAs, the centre conductions should be hard, springy BeCu, but instead it's soft brittle brass
