Hi all,
I got a good deal on a station from a brand that is better known for its soldering wire/pastes. The company is based in Wuppertal and has released three new soldering station units, all digital. The Industa 550 is their entry level and where I live retails for EUR130 but in Germany it can be bought for less than EUR90. I did play with their previous Industa 300 series and they felt like crap, very bad build quality on the outside, soldering pencils looked like a $3 Radioshack one, but have not used one. So, here`s the new line.
The good
The build quality is fantastic, looks better than on the pictures. Case is nice, made of powder coated aluminium. The unit is bulky, bigger than my Weller EC2100 and weights 2kg. The back AC inlet looks very much like a Schurter, uses a computer type socket cable. Connector is very tight and looks of good quality. The pencil feels ok, nothing fancy, although I do prefer my EC1201A. The cable is good but does not seem to be silicone rubber, not as hard as on a RDS 80 but could have used silicone cable instead. It`s not an obstacle when soldering. Tip hits 380C faster than the advertised 50sec, my chronometer showed 38 seconds indeed in what was around 28C room temp. Station reacts quickly and is advertised to be ESD safe, which it is as seen later. The plug is to the back. Transformer is a torroid with dual secondaries of 24VAC and 9VAC. PCB design and soldering appears too clean for a knock off (I will make a point on this later) and the elements look genuine, like the ones I get from Mouser. All wiring inside is laid out very nicely with extra thermal shrinking tape and silicone boots around the cable ties. Cabling is pretty thick, thicker than on the EC2100. The build quality, with one exception (the iron plug socket) seems better than the Wellers I`ve had. It feels very robust as a unit. It was also nicely packed, the power unit, iron and the stand had all their own separate white cardboard box inside the main one. The unit is also supplied with two extra tips with the main one being a conical (which made me look up if it`s not a knock off). The manual is very limited and consists mostly of warnings to not touch the tip when hot and so on (even to not use the station when under illegal drugs! - formulated this way exactly - made me laugh).
The bad
The display is really too bright and can be quite annoying, especially if it is darker. The iron socket is misaligned (not sure if this was made on purpose, but why would they). The soldering pencil looks identical to the Aoyie and heating element does not appear to be ceramic (but is advertised as high quality ceramic heater) and has no producer name on it. The soldering iron stand also resembles what was the Hakko 936 but is slightly modified, having elliptical holes to the top. The supplied sponge is narrower than the bed inlay and its annoying to touch the stand almost every time when I need to wipe the tip. Temp tolerance is given as 5% which is a lot - at 300C that`s 15C! I don`t have an infrared thermometer to check its accuracy but can do this soon. Besides, under it there are no large circles as in the original Hakko 936, which makes me think if this could be another nicely dressed Hakko 936 knock off. Stannol is a big brand and I doubt they`d do this but the pencil and the stand look so similar to the Aoyie clone.
What do you, guys, think - can this be a OEM unit made by Hakko for Stannol, or maybe the power unit is in house design and the soldering iron and stand are OEM built by Hakko for them?
Or does this look closer to another knock off?
