What are the pros and cons of stranded- vs solid-core coaxial cable. I previously assumed that stranded-core cable would generally be higher quality than solid-core cable for two reasons: (1) more flexible, and (2) slightly higher conductivity at high frequencies. However, looking through Pasternack's catalog I've noticed that most of the high frequency and more expensive cables are solid, not stranded, core. Why is this?
If I were to hazard a guess as to why solid-core isn't a disadvantage in terms of flexibility it would be that other factors (such as dielectric material) dominate the flexibility. For example, I have 086 cable that is very flexible but also solid core. Does this mean that you'll damage other aspects of the cable (e.g., dielectric) before damaging the center conductor from bending? If this is correct, though, it still doesn't tell me why solid core is apparently better, just why it isn't worse than stranded-core.
So, does solid have advantages over stranded and, if so, what are they?
