Author Topic: Teardown: $10 wireless HDMI kit  (Read 3944 times)
Offline NiHaoMikeTopic starter
    • Facebook Page
« on: April 07, 2016, 07:17:27 am »
There was a discount on the LG AN-WL100 wireless HDMI kit, so I got one. After tearing it down and playing with it, I decided to get a few more as they're clearly very useful.
The chipset used is the AMN2120, which is rather interesting in that it's available in medical grade. Clearly the protocol must be well designed and very robust! It supports up to 1080p60 in the 5GHz band and the quoted latency is less than 1ms.
The schematics for the motherboard in the base unit can be found online and it runs Linux. Rooting it is reasonably easy with a serial cable and LGMOD_S7, although I haven't yet found anything interesting to do with root. There's a lot of room in the base unit which opens up a lot of possibilities for some DIY projects.
Offline bingo600
Re: Teardown: $10 wireless HDMI kit
« Reply #1 on: April 11, 2016, 07:40:55 pm »
Some info here
http://csmatt.com/notes/?p=62
/Bingo
Offline pcbroute
  • Country: ru
« Reply #2 on: March 24, 2018, 07:51:23 pm »
How do you think, it is possible run one transmitter with two receivers in the same time? How pairing is work?
Offline Beamin
  • If you think my Boobs are big you should see my ba
« Reply #3 on: July 23, 2018, 02:37:47 am »
How big in this? I would want the transmitter end to be small so you could have it be semi portable. The TV end wouldn't matter. Does it have a SMA or connector for an antenna?
Max characters: 300; characters remaining: 191
Images in your signature must be no greater than 500x25 pixels
    • Facebook Page
« Reply #4 on: July 23, 2018, 03:13:13 pm »
The whole unit is about the size of a DVD player (pretty much just to fit all the connectors), but the transmitter board is quite small.
