This is a Tektronix TWD120 100MHz dual channel digitizer. It's a PC-based oscilloscope from around 1994 with a SCSI-2 interface. The software is 16-bit originally for Windows 3.1, but it'll run in any 32-bit Windows. Only problem is it seems to crash when the window is resized beyond SXGA resolution (1280x1024).
MC68331 16MHz 32-bit Freescale MCU
4x M5M51008 (1Mbx8) 4MB SRAM
DS1630AB 32KB NVRAM
2x AM28F020 (256Kbx8) 512KB Flash ROM
NCR 53C90A SCSI Controller
MC68230 Parallel Interface/Timer
MC68681 Dual UART
8x IDT7164S20Y (8Kbx8) 64KB SRAM buffer for ADC?
My question: Is this good enough for a beginner to learn? Or is it too outdated? This is what I was told by another TWD120 owner.
The scope is better then I was thinking only a bit slower when you use more then 500 points like 5000.
I was very happy with my analog scope but this is not a bad piece of equipment I have to say it is far better then a 125mhz lecroy but those are from 1984 or so but claims to be 125mhz those have already a bit trouble displaying a 4Mhz square this one
According to the specs of my signal generator it should have a risetime in squarewave mode of less then 20ns and the scope says 10ns that is perfect, only good scopes display fast rise time like this.
A lot of features and it works up to 200mhz or more.
First I was shocked about the 20milliseconds fastest sweep time in the twd 120 viewer program because then it would be more bad then a homemade scope anno 1986 but now in the real program you have to use it goes down to 5ns that is not bad as you imagine you can zoom into the signal when you look at a 100Mhz signal, also the screen is big and clear compared to a small analog scope screen otherwise 5ns would be a bit low maybe.
I don't know enough about scopes to know if that makes it good enough to keep, or if I should invest in a lower-end Rigol.
I bought this a long time ago and have mainly just used its AUTOSET function in the software to view waveforms, but I'd like to learn more advanced scope usage.
