Author Topic: Teledyne TW-1 Stripall thermal wire stripper  (Read 4298 times)
Online FraserTopic starter
« on: January 26, 2016, 01:46:53 pm »
I recently purchased a very nice Teledyne TW-1 Stripall thermal stripper. Mine is the version without the temperature controller and just heats up to Max when the button is pressed.
http://www.teledyneinterconnect.com/products/wire_strippers/wirestrip.asp
The TW-1 also has the option of a controller that sits in line with the 110V supply. I thought it likely that this is just a simple light dinner circuit using a Triac to chop the mains waveform. I am no longer so sure though as the TW-1 is a transformer, so inductive load, as opposed to the resistive load expected by a lamp dimmer.
IIRC simple dimmer circuits do not work well with motors and transformers. Back EMF can even kill the Triac.
Does anyone have the Stripall controller that they can open and photograph please. I would like to know what Teledyne have done to control the voltage fed to the transformer.
The TW-1 is also available with the controller hard wired to it, under the model name TWC-1.
Maybe it is just a simple lamp dimmer circuit with some back EMF protection ? That would surely make the transformer in the handpiece buzz though?
Thanks in advance
Fraser
« Last Edit: January 26, 2016, 01:57:53 pm by Fraser »
Offline zapta
Re: Teledyne TW-1 Stripall thermal wire stripper
« Reply #1 on: January 26, 2016, 01:53:58 pm »
Use a zero crossing controller?
I just press the button for short time if I want lower temperature.
Offline zapta
« Reply #2 on: January 26, 2016, 01:55:12 pm »
Use a zero crossing switch?
Offline Wuerstchenhund
  • Able to drop by occasionally only
« Reply #3 on: January 26, 2016, 02:01:50 pm »
I recently purchased a very nice Teledyne TW-1 Stripall thermal stripper...
And in what way is that related to Test Equipment?
« Reply #4 on: January 26, 2016, 02:07:39 pm »
Damn, it should be in the 'other' category as it is a tool.
Mods please move this as at least one member objects to its existance here.
We all make mistakes.
« Last Edit: January 26, 2016, 02:09:58 pm by Fraser »
Offline zapta
« Reply #5 on: January 26, 2016, 02:12:23 pm »
Some more benign than others.
« Reply #6 on: January 26, 2016, 02:23:13 pm »
Just found a useful thread covering this very topic...... Right here on the forum
https://www.eevblog.com/forum/projects/ac-voltage-control-in-transformer-secondary-using-triac-in-priomary/
The circuit used for controlling an arc welder looks to be suitable.
As Zapta has stated, I can just decide how long to press the button for and see how I get on with that technique. The KISS principle at work.
I would still be interested to see inside the Teledyne controller though.
Offline john_p_wi
« Reply #7 on: February 05, 2016, 06:34:19 pm »
Sorry, I looked at the controller on mine and it is riveted together.  Risk of damaging something inside when drilling out the rivets is too high for me to go through the effort, I also expect that is why no one else has provided any info.
« Reply #8 on: February 05, 2016, 08:16:01 pm »
@joun-pi-wi
No worries. Thank you for checking. I would not expect anyone to drill out rivets to look inside a unit for me. As you say, this may be why there are no pictures or comments on the controller. It is likely to be similar to an AC welder controller so I can always buy one or use a variac :)
Thanks again
Fraser
Offline zapta
« Reply #9 on: February 06, 2016, 12:04:09 pm »
Any safe way for figuring the signal from the outside? E.g. a few wire loops on one of the arms, connected to an oscilloscope?
