The little Stanley 5ltr compressor arrived today I had it working within 10 minutes of arrival but it does have an issue as you will see.
The compressor does not use a 12V car tyre inflator pump but the pump is similar in appearance. The small PCB that I saw on the parts diagram is a simple 240V AC to DC converter using a bridge rectifier. The motor is rated at 230V DC and is a universal commutator type. The 3A 1.25" glass fuse on the AC to DC PCB had failed. I temporarily replaced it with a slightly more resilient 3A plugtop fuse that can better withstand inrush current.
The compressor fired up fine with this fuse fitted but as I always tell people, fuses do not fail for no reason. In this case the fuse had not failed in a manner associated with a massive over current event. It had slowly cooked and melted. A sure sign that it was placed under excessive continuous load over a period of time rather than a catastrophic overload event.
The compressor reached 7 BAR and I could hear an air leak. The unit should achieve around 8 BAR and then the pressure switch should cut the power to the motor. This never occurred. I had found my slow overload. The pressure switch could not operate as 8 BAR was never achieved. The motor ran for too long and the 3A fuse was thermally stressed by the long duration of the current through it and eventually failed with a wimper rather than a bang
The air leak is being caused by the safety over pressure valve that starts venting at around 6.5 BAR. Way too low a pressure. If I hold the pressure relief valve closed, the compressor operates normally and cuts out at just out. BUT I need to check the pressure at which it is cutting out as it seems a little high to me. Time to check the specs and you tube videos of these running. It could be just inaccurate gauges as they do not tally with each other. Simple tests to perform so of no great concern. I have a spare pressure switch if needed. I will order a new safety pressure relief valve and they are cheap which is god news.
So I have a working mini compressor. It s a lot quieter than expected and the you Tube videos are nt fair to this little unit. Its noise levels are more than acceptable in the lab and it is a lot quieter then its bigger brother, the 24L direct drive compressor that I repaired at the beginning of this thread. The little 5L unit does nit have the harsh high frequency noise that I expected, ts more like my air brush compressor noise. Very nice.
Pictures follow.......
Fraser
